Question about wiring amp to stock headunit
Im trying to wire my amp to my stock headunit. Everything is wired except the signal cables. When i bought my car it came with a pac aai (auxilary audio imput) box. I figured that would be where it needs to be wired. I was wrong. Theres got to be something i can hook up to allow a signal to be sent to the amp. Can this also explain why my component speakers are not sounding better than stock. I need you help.
Originally Posted by absoundlab
when you say signal cables you mean rca's right? if that is the case them you can use a hi/low
studman ftw
http://maxima.theowensfamily.com/audiowiring.asp
Or, read the stickies since Kev spent the time to make the post.
Parag, stop feeding the noobs
Looks like we need you to lay the smack down some more Nilesh. You were on a roll before....
Originally Posted by nismos14
Just tap rca wires to the outputs from the HU, they are already low level and run rca's from that.
I didnt see where he said he has Bose. You've already confirmed that he does?
Originally Posted by burnurass
He's feeding ihs own kind.
I was preoccupied for a while with work/class/bathroom renovation. I'm always around, just a phone call away. But I've got some free time now so I'll be schoolin noobs once again.
i haven't figured our how to tap into my headunit either, i wanted to use my stock headunit for my system, but no luck so far. not even sure which hi/low thing to get, since all the threads i found for people that had bose system, which i dont.
ive got a high-low line output converter for sale. it has the rca preouts all you do is hook them up to the wires going to your stock speakers and you get an rca hook up, worked perfectly in my old car with bose sounded good too, but i now dont have a need for it.
http://forums.maxima.org/showthread.php?t=517869
the hi low has a left and right input. its positive and negative on each side. these wires get tapped onto the positive and negative wires on your rear speakers. you can use t taps to do this. and from there you plug in your rca and run that to the amp and now your amp has a signal
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
doobadoo
Aug 15, 2015 06:43 PM
