what to do while waiting for new head unit stuff
Old May 14, 2007 | 01:22 PM
replicant's Avatar
so basically its killing me that i have to wait for all of my new gear to be shipped to me, so i've been compiling a list of stuff to be sure is good to go to minimize the amount of work to be done when the head unit and modules arrive.
these are by no means the only things that has to be done for all setups, but for me this is all i can think of, i'm sure more will need to be done when i actually receive everything, but this is merely a preemptive strike at getting things ready.
please feel free to add/change this list from your own experiences.
  • Make sure all rcas are ran to the front (audio/video and related grounds)
  • Turn amp's gains to minimal levels (i could be wrong here, but i don't want to have these turned up to begin with, right?)
  • Make sure you have a proper ground ready to go (proper meaning paint sanded down and the necessary hardware in place to screw it down, etc)
  • Stock/old headunit pulled out and space cleared for new dash kit/headunit
  • Map out where you are going to mount/place the various modules (if any) -- in this case 2 to start with and eventually 3 total (ipod, bluetooth, sirius)
  • Decide where GPS unit will go and know how and where to run the necessary cable(s) for that spot
  • Know where to mount/install/wire steering wheel module/adaptor
  • Decide and prep area for bluetooth mic (if there will be a mic to be installed)
  • Prepare speaker to be used in conjunction with bluetooth module
  • Find place to mount said speaker and get that area ready
  • Decide on ipod location and map out wiring for that
That's all I got thus far. Any of you suggest anything else?
Old May 14, 2007 | 01:36 PM
burnurass's Avatar
well not really anything to add to your list....but notes for when you actually DO the install. If you're not driving your car, take out your cluster and have it ready to tap the VSS wire.
DEF. figure out where you want to put all the modules. Some hints from my install:
- bluetooth unit..I just threw it on the bottom of the dash opening
- GPS unit...the AVN is all in one. NO "seperate" GPS unit. The Antenna I have sitting on my dash right behind the clock (you'll see a spot to mount it between two defroster vents)
- Bluetooth MIC...I ran that up to the top of the A Pillar. The Controller I ran down the center console and snuck it up the ebrake handle hole and mounted it right behind the cup holder.
- Ipod adapter...RIGHT on the left of the dash opening you can tuck in the wall (should be able to see if when you have everything OUT).
I ran the ipod cable straight to the glove box...nothing really difficult about that...should be able to feel your way over there.
Old May 14, 2007 | 01:58 PM
replicant's Avatar
Thanks for the response J. Ok so basically from your input here is what i'm doing in terms of module/ipod/gps installation.
Based on my current setup, I am going to refab a new plate to mount the bluetooth module, and i might as well run the remote base **** and mount it up there to. I MIGHT can mount the speaker for the bluetooth **** thingy there too. It will be a tight fit but I might can fit it in place of where I currently have my cell phone holder (to the left of the brushed-aluminum ****). For the ipod, I'm going to run it to the extra pocket thing at the center console (the part that is about 2" deep. For the bluetooth mic, I'll run it to the a-pillar and drille a couple of holes in a uniform pattern and might even stretch a piece of that boom mic foam across it (it will be minimal in size i'm sure). The GPS antenna/puck i'll put where you have yours (good spot!). Everything else I'll just tuck away in the dash maybe with velcro tape or something.
Now comes the VSS wire, i've heard so much about this, but haven't read anything in terms of where it is, etc yet. TO save me from the poor "free, non donating members" search, could you tell me a bit about it and what it is for and where it is (and its color, pink, i've heard)?
When you say cluster you mean the speedometer cluster? I've not removed that yet, so hopefully i can find an exploded parts diagram of that.
Thanks again J.
Old May 14, 2007 | 02:11 PM
burnurass's Avatar
http://www.innerbean.com/housecor/chrome_rings.html
Use that to get behind the cluster.
It's the CENTER HARNESS..and yes it's the pink/another color (i forgot) =P.
I actually just tucked the microphone for the bluetooth unit up there...didn't permanently mount it and have had ZERO problems.
ALSO..forgot to mention the nav antenna you can pop out the clock (hard at first) and run the wire from there for a cleaner/easier install.
Good luck man
Old May 14, 2007 | 05:06 PM
Greeneyes's Avatar
Yeah I put all my modules in the space under the shift **** and stereo... The iPod unit I was able to fit sitting flat behind the actual headunit.
Definately take the Gauge Cluster out for the VSS wire... as Burnurass said its a Pink/Blue wire on the connector right behind the Speedometer...
My GPS antenna I put right behind the Clock as well with the wire run right under the clock assembly... Pretty nice spot for it.
My Bluetooth mic I installed behind my rear View mirror...ran the wire around the top.
Old May 14, 2007 | 05:45 PM
replicant's Avatar
greeneyes, pics of your setup?
Old May 16, 2007 | 06:44 AM
replicant's Avatar
welp today is the big day. the avn6610bt + accessories arrive today (the ipod control isn't here yet though *sigh*). the gxe dash kit arrived yesterday. so basically expect lots of pics n stuff. thanks burn and greeneyes for the info.
Old May 16, 2007 | 08:09 AM
replicant's Avatar
woot, and it just arrived. thanks don!
Old May 16, 2007 | 10:02 AM
burnurass's Avatar
less posting...more installing. MY TURN to bust your *****.
Old May 16, 2007 | 10:57 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Get to work foo !
Pearl96Max's Avatar
Yes Jeff ...have your way with him now.
Old May 16, 2007 | 11:49 AM
replicant's Avatar
slow down there turbo, the ipod module won't even be in until friday
i was gonna do everything at once this weekend.
i will say though, don, i'm very impressed by the shipping packaging. it was pretty rad to see the peanuts in plastic bags instead of loose everywhere.
Old May 16, 2007 | 11:57 AM
Pearl96Max's Avatar
Hey what can I say ... Im good at my job.
Old May 16, 2007 | 12:23 PM
replicant's Avatar
i can just hear and feel the bump now. oh btw i ntoiced the map disc is from 2005!? is there an updated one available? that is somewhat annoying considering where i live is pretty newly developed a of late 2005. also there is no way to browse POI categories right?
Old May 16, 2007 | 12:46 PM
Pearl96Max's Avatar
JUst when I start to think your a really smart guy.... ya see that little C inside of a circle next to where it says 2005? Ya also see the same where it says 2007? Know what that is?
Old May 16, 2007 | 12:56 PM
replicant's Avatar
hah yeah i scanned it briefly, STFU. go away and shut up.
Old May 16, 2007 | 12:57 PM
Pearl96Max's Avatar
Hahahaha you pwnt yourself then.
Old May 16, 2007 | 01:19 PM
burnurass's Avatar
Ipod module takes 5 minutes to install...10 minutes if you including taking apart your dash.
DO it now bish! I already found a spot for your Ipod module, all you gotta tap is the yellow and black wire. Leave the settings on the module to default. Run the little wire to the glove box. DONE! no excuses!!!
Old May 16, 2007 | 01:25 PM
replicant's Avatar
haha. ok well tell you what, i'm at the office right now and stuff, then i gotta head home, change clothes, going to see 28 weeks later with some of my boys then i'm gonna pull an all nighter putting this bish together.
Old May 16, 2007 | 01:26 PM
replicant's Avatar
dedication mang, dedication.
Old May 16, 2007 | 01:31 PM
burnurass's Avatar
lol could've just said you were at work. Then we wouldn't have busted your ***** till AFTER 5PM.
Old May 16, 2007 | 01:52 PM
replicant's Avatar
you and i both know that work is no excuse! there is always time for the car. car takes precedence of women and work, though sometimes you have to make exceptions
Old May 16, 2007 | 01:54 PM
burnurass's Avatar
LOL good luck tonight.
Old May 16, 2007 | 10:51 PM
Greeneyes's Avatar
I'll be posting pics of my setup soon... I dont have my sub in yet... Me and my Pops are gonna try and build the Sub Box ourselves....
So far so good...
Old May 17, 2007 | 05:55 AM
burnurass's Avatar
Seth ya still working on it? Pics/results not found.
Old May 18, 2007 | 07:05 AM
burnurass's Avatar
bump.......seth you still alive?
Old May 18, 2007 | 07:30 AM
replicant's Avatar
yeah i'm slackin' got most everything wired up late last night save for the VSS wire and the steering wheel module.
Old May 18, 2007 | 07:51 AM
Pearl96Max's Avatar
lazyass
Old May 18, 2007 | 10:13 AM
replicant's Avatar
ok i came home for lunch and tore apart the cluster to get the VSS wire hooked up, so that is done, i ran the parrot bt controller/**** thingy. so now i think all that is left is to hook up the steering wheel controller, and plug up the othe rmodules (ipod module will be here this afternoon, yay overnight shipping). then plug in teh speakers and let the fun begin
Old May 18, 2007 | 11:44 AM
replicant's Avatar
woot, fedex tracking ish says the ipod module arived at my house.
Old May 18, 2007 | 11:52 AM
replicant's Avatar
jeff, where did you wire the yellow/black? where did you tap it into?
Old May 18, 2007 | 01:24 PM
replicant's Avatar
this work day wont' end fast enough
i just wanna finish installing my 6610.
Old May 18, 2007 | 01:45 PM
Pearl96Max's Avatar
Slacker !!
Pearl96Max's Avatar
Yellow = Constant
Black = Ground
Run them with the Elan cable to behind the HU and connect there n00bcakes.
Old May 18, 2007 | 01:49 PM
replicant's Avatar
aight, thanks. when i get home i'm gonna wrap this ish up.
Old May 18, 2007 | 01:52 PM
burnurass's Avatar
Originally Posted by Pearl96Max
Yellow = Constant
Black = Ground
+1
What NOOBMASTER SAID.
Old May 18, 2007 | 02:05 PM
replicant's Avatar
For the record, i knew what yellow/black represented (it says what it is in the instructions!) but just wasn't sure where YOU guys tapped it into. Bear in mind, I odn't have the unit or cables here in front of me.
Old May 18, 2007 | 02:16 PM
replicant's Avatar
i'm just trying to recover some of my apparent n00bness.
Old May 18, 2007 | 02:35 PM
Pearl96Max's Avatar
Lies !!!
Old May 18, 2007 | 02:43 PM
burnurass's Avatar
Lies !!!
Hey stop whoring and sell me that Parrot Kit on your shelf.
Seth GET to work!! we what a FULL review by tomorrow morning.
