Will the charging system still run at 14V with this system installed?
Whats Good? Here's the deal. I'm just looking for a simple yes or no.
JBL gives 1114 watts RMS x 1 to 2 L5s
Kicker gives 120 watts rms x 4 to MB quarts
Pioneer 68HP000 sumthin sumthing deck
220 amp altinator
HC1800 kin***ik battery (1900A)
That is a list of stuff i'm gonna put in to run the system. I also have a 2.4 cap and 1/0 guage wiring kit, 100 amp fuses, and ditribution black. I need to know if this car is going to run at 14.4V becasye the JBL amp needs that for high performance. The original altinator as ya'll should know is 110A, and the battery I have is 365A.
Will this set up keep the car going at 14 volts
220 amp altinator
loose the cap, thats only hurting your electrical system. and do you mean distrobution block?
you know 14.4 just means 'when the car is running', right?
the more amps you install in the car, the harder time your alt is going to have keeping them running. I think you'll be okay.. you'll probably get some slight dimming, but its not like the JBL isn't going to work if you don't see 14.4.
Oh man. This is an excellent thread. Where do I begin?!?!
I feel like a kid in a candy store.
bout the mispellin, my bad. I tend not to use proper grammer on the internet sumtimes
