need head unit help
Old May 22, 2007 | 04:45 PM
WeeZyFellA's Avatar
need head unit help
hey guys hows it going, I bought the Scosche install kit for my new head unit and I can't remove the mounting brackets off the stock head unit to use with the install kit. Its a bit frustrating, I already freed the heads of two of the screws(I guess those aren't coming out now) and broke the tip of one of the screw drivers, and a drill doesn't help either. seems like the screws are rusted(but from where?) in or something. any advice?
Old May 22, 2007 | 05:01 PM
burnurass's Avatar
use a 10MM socket wrench (i think it's a 10mm) and TIGHTEN IT to break it loose. Then it should be broken loose.
Old May 22, 2007 | 05:05 PM
WeeZyFellA's Avatar
they are flat head screws, not nut style screws. but if they were nuts it wouldn't be a problem.
if your thinking of the 4 screws that hold the unit into the car, its not those. its the 6 screws, each side, on the left and right of the unit that hold it and the climate control together that need to be removed.
Old May 22, 2007 | 08:07 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Theyre reccessed flat screws n00b, havent you been in there enough to know this already?
Old May 22, 2007 | 08:08 PM
Pearl96Max's Avatar
Try tightening first til it cracks, then loosen with ease. Make sure the driver is in there firmly, even tap it a bit with a mallet to confirm.
Old May 23, 2007 | 07:33 AM
WeeZyFellA's Avatar
no luck with that even, they wont budge at all.
i have everything out, only to get no where.
Old May 23, 2007 | 07:41 AM
Pearl96Max's Avatar
I would have to say drill em out then.
Old May 23, 2007 | 08:10 AM
replicant's Avatar
i had to drill out 2 of mine. the rest came out using don's method.
Old May 23, 2007 | 08:11 AM
WeeZyFellA's Avatar
that sounds like a lot of work, only leading to more problems when I have to turn it back to stock with broken screws lodged in there or metal chipping stock in the unit from the drill.
On a side note, does the Metra kit use the factory brackets? or any of the factory pieces to install a new head unit. even though its black I might as well buy that kit then.
Old May 23, 2007 | 08:19 AM
burnurass's Avatar
LOL i thought he was talking about the bolts holding the headunit.
But I did give him a hint to tighten it first...lol.
Old May 23, 2007 | 08:20 AM
Pearl96Max's Avatar
blah n00b When ya comin for the BT?
Old May 23, 2007 | 08:23 AM
burnurass's Avatar
probably saturday/sunday? Is that ok?
Old May 23, 2007 | 08:35 AM
Pearl96Max's Avatar
Sure, thats fine
Old May 23, 2007 | 06:07 PM
cprx7's Avatar
Mine came out easily with an impact screwdriver like this one
http://autorepair.about.com/library/...bl255a-lib.htm
good luck
Old May 23, 2007 | 07:13 PM
mendon99's Avatar
tastey wheat
i used a titanium bit and a powerful drill on mine, came off with ease..
others though, yeah just tap a good driver with a hammer lightly and try to break first.
the last screw you can actually twist the bracket a bit around the radio and it will break the screw loose.
Old May 24, 2007 | 10:25 AM
WeeZyFellA's Avatar
thanks guys, but no amount of force or pressure is making them loose, i guess my only option left now is to drill them out or try the impact screw driver.
i thought if i used the metra kit now i would avoid having to use the brackets, but that too uses the brackets.
Old May 24, 2007 | 10:28 AM
Pearl96Max's Avatar
Using the Metra kit will still use the brackets, but once theyre removed the first time everytime after is cake.
aw11power
Oct 10, 2021 04:57 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
