good idea or no?
Old Jun 6, 2007 | 08:46 PM
blimblam's Avatar
good idea or no?
i don't have a lot of room in my maxima for 2 12" CVRs. so i was wondering if this unique idea would work. can i put one sub in the spare tire well and one in a ported box in the trunk? or will the one in the spare tire well cause complications?
Old Jun 6, 2007 | 08:54 PM
kpr10is's Avatar
Would it work? Yeah. Would it sound good, with one being sealed and the other being ported? Probably not so much.
Old Jun 6, 2007 | 09:14 PM
nismos14's Avatar
§è~® f®ÈÄk
Not a good idea, if space is a concern just go with one ported.
Old Jun 7, 2007 | 07:01 AM
blimblam's Avatar
if any of you have fit 2 12" CVRs in your 4th gen, what dimensions did you use? and what type of box?
Old Jun 7, 2007 | 07:06 AM
nismos14's Avatar
§è~® f®ÈÄk
Is it going to help you if someone fit them in a box that took up the entire trunk?
You need to do some research on box's and find out on-line about the dimensions that will best suit your needs. There's plenty of sources to use on-line and they will all get you the information you need.
Old Jun 7, 2007 | 08:27 AM
Fast1one's Avatar
You can easily go with two CVRs ported if you want to sacrifice the room, there are several good premade designs here: http://www.caraudio.com/forum/showthread.php?t=137804
You can also have someone design a box specifically for your car and subs for an average small fee of ~ten bones. Just register over there and search
Go for around 4-4.5 cubes tuned in the 30-35 hz area for a good mix of the higher bass and low lows. BTW the biggest I ever fit in a 4th gen was about 36 wide, 26 deep, and 14 high while being well below the torsion bars and still being able to remove the box fairly easy. I also had around 6 inches of clearence between the trunk and the front of the box, good luck
Old Jun 7, 2007 | 08:45 AM
blimblam's Avatar
i'm a registered member over there.
i've decided im going to just go with one sub for a daily driver and sell the other one.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
pkfinn
Jan 3, 2016 02:55 PM
follyburr
Aug 7, 2015 09:50 PM
13Maximasv
Aug 7, 2015 10:56 AM
