880PRS VS CD7100 Comparo
Old Jun 11, 2007 | 07:59 PM
nismos14's Avatar
§è~® f®ÈÄk
So I recently went from a DEH-P880prs to an Eclipse CD7100. I can tell you now that I do miss a few features that the 880 had that the CD7100 either doesn't or I have yet to tap into.
1) Independant speaker level control - 880 has it, cd7100 does also.
2) Independant phase control for each speaker - 880 has, cd7100 doesn't.
3) Full subwoofer control - Level, phase, mono or stereo output - Pio has all CD7100 only has Phase and Mono vs. stereo setting.
4) 15band eq on 880 was very nice, the 11 band PEQ seems to be more customizable and a great feature, I definately prefer the PEQ over the 15-Band with the customizability.
5) 880 only had the 15band, CD7100 has Bass, Mid, Treble controls as well as the PEQ. This is a nice touch.
6) 880 has no built in aux and no built in USB, CD7100 has both but the interface is kind of blah on the USB and I have not yet tried out the AUX though.
7) 880 full subwoofer control - CD7100 Non fade with no level control when in 3-way mode, Non-fade can be adjusted +_6 when in 4sp + subwoofer mode.
8)Area shot feature - this is a pretty neat feature to throw into the mix that Eclipse has. I got it to work the other day and am very impressed with it. It's a good backup feature but along with it I would always keep a couple of backup maps etc. Works well though.
9) 880 comes with a Mic, CD7100 does not, not THAT big of a deal however it is nice to know that you don't have to purchase anything additional in order to run the auto TA's etc.
880's intereface is straight forward and very easy to use. The CD7100 is a bit more complicated and I feel as though I have yet to tap into the full number of features that it has or am just not sure how to use them yet.
Here's the most important part - SQ -
I think there's no question that the CD7100 has better SQ. There are just things I noticed right off the bat without any tuning that give the CD7100 the edge in that regard.
I also find that the Audiocontrol Matrix that I originally purchased to increase the level of the 880's outputs is no longer necessary. The Eclipse has much stronger outputs with no know noise issues like the 880 has.
Those are my impressions so far, maybe more to come if I find more features etc.
Old Jun 11, 2007 | 08:17 PM
mach999's Avatar
I thought the 880 did have an aux input. What's the input on the bottom of the face?
Old Jun 12, 2007 | 05:02 AM
nismos14's Avatar
§è~® f®ÈÄk
Thats for the t/a auto eq mic.
Old Jun 12, 2007 | 06:35 PM
filtor1's Avatar
Good stuff. I would almost 100% agree. I can't get the CD7000 back, so I will be purchasing another. It will go in the car for a while so I can play with both. The other will end up in the truck.
Old Jun 12, 2007 | 06:40 PM
nismos14's Avatar
§è~® f®ÈÄk
CD7000 or 7100 this time around? Whats wrong your buddy likes it too much?
Old Jun 12, 2007 | 06:45 PM
nismos14's Avatar
§è~® f®ÈÄk
Oh let me add
10) cd7100 lets you adjust TA in steps by millis second, pio only does this by distance in either centimeters or inches
11)E-iSERV data can be uploaded from either the unit to the pc or the pc to the unit and you're able to fine tune right from your pc. You can setup a flat FR by adjusting the PEQ on-line and saving to USB then uploading that data to the HU, you are then unable to adjust any of the TA settings on the UNIT itself, which is fine, just a quirk.
Old Jun 12, 2007 | 07:03 PM
The Law's Avatar
I R The Law
Damn I want this unit or the 5100
Old Jun 12, 2007 | 08:18 PM
filtor1's Avatar
Most likely the 7000. I have no need for 8V. Yes, he likes it alot. He said I could have it back if I wanted, but if he is that happy, I will just have to buy another.
Old Jun 13, 2007 | 04:53 AM
nismos14's Avatar
§è~® f®ÈÄk
Nice. There's a guy sellign a cd7100 for $420 on CA.... just fyi, I think I have the last one Don had in stock Though I'm sure he could get one with a snap of a finger.
Old Jun 13, 2007 | 05:59 AM
brusk's Avatar
I'd have to agree with most of what was said. I ran my Fantom Face 7897 Alpine for the last 4 years and just switched to the CD7100 about 4 days ago.
1. The only thing I saw on individual speaker volume was the ability to adjust DB under time alignment.
2. Not sure if my alpine had independant phase control either never looked.
3. Subwoofer controls would be nice.
4. Alpine only had 5 band I beleive so definate upgrade
5. Havn't seen any mid, bass, treble controls yet.
6. Hopefully the USB works good that's why I bought mine for. And SQ
7. Don't have my sub quite it yet so havn't played with that.
8. Area Shot, why? They should have added a usefull feature given the type of HU no gimmicks needed.
Overall I like it. It does sound a little cleaner but it definately takes some getting used to. Certain features that I havn't found yet is a pause button. It seems to take forever to read my CD, it is scratched up pretty bad but the alpine never had a problem or hesitation. So overall I'm not impressed with the HU itself but the sound is good. I'm sure some would say that my alpine was complicated but I've been dealing with alpines for 15 years so I was probably used to how they were setup.
Old Jun 13, 2007 | 06:04 AM
nismos14's Avatar
§è~® f®ÈÄk
If you hit the center button on the rotary control it'll take you to bass mid and treble controls if you are in 3-way mode (also loudness, SVC control as well [in 3-way mode] and NF setting if you are in 4 sp + sub mode). So far my experiences with the USB have been great. I like it alot and it works well. Not the fastest in the world but it reads mp3's pretty fast.
Old Jun 13, 2007 | 06:06 AM
nismos14's Avatar
§è~® f®ÈÄk
Also noticed that the HU has to be mounted further out to fit my dash kit properly and to be able to open it without rubbing anything. Right now I have to leave the trim ring out until I get a chance to re-mount the HU.
Old Jun 16, 2007 | 06:38 AM
1996blackmax's Avatar
Parag, you finally did it .
You will not get anything near the level of tuning that the CD7100 provides with the 5100. If that is what you are after, I would save a little more and go for the 7100.
Old Jun 16, 2007 | 07:06 AM
nismos14's Avatar
§è~® f®ÈÄk
I agree with Juan, 7100 all the way if you need any high level of tuning.
Old Jun 16, 2007 | 05:05 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Nah I like my Pioneer better.
Old Jun 16, 2007 | 06:08 PM
nismos14's Avatar
§è~® f®ÈÄk
I knew you would.
When you gonna come to the darkside of eclipse?.......
Never again right? You're too cool for eclpse
lol
Old Jun 16, 2007 | 06:13 PM
Pearl96Max's Avatar
No, Im not too cool, but this is...
Old Jun 16, 2007 | 06:24 PM
nismos14's Avatar
§è~® f®ÈÄk
Wtfs? lol I was expecting something else.
That going into the G?!?! Or teh van?
Old Jun 16, 2007 | 08:02 PM
Pearl96Max's Avatar
Dunno yet, its between this an suttin else. What were you expecting?
Old Jun 16, 2007 | 08:03 PM
Pearl96Max's Avatar
and that unit above of course gets paired with...
Old Jun 16, 2007 | 08:37 PM
mach999's Avatar
That's the most beautiful thing I've ever seen.
Old Jun 17, 2007 | 08:49 AM
nismos14's Avatar
§è~® f®ÈÄk
Something that most would expect even LESS than a pio in your vehicle.
My vote goes to the Pioneer ish, fo sho.
Old Jun 17, 2007 | 08:53 AM
Pearl96Max's Avatar
I have another unit that may go in instead...
Old Jun 17, 2007 | 09:11 AM
nismos14's Avatar
§è~® f®ÈÄk
Pics? Already have it? The one I'm thinking of prolly..
Old Jun 17, 2007 | 09:15 AM
Pearl96Max's Avatar
Nope, maybe maybe not.
Old Jun 17, 2007 | 11:38 AM
BBOYSTEVIE's Avatar
Back from Hibernation
Nice HU/Combo don. I'd LOVE one of them.
Old Jun 17, 2007 | 12:09 PM
Pearl96Max's Avatar
Ill most likely be seeling it too.
Old Jun 17, 2007 | 12:13 PM
nismos14's Avatar
§è~® f®ÈÄk
You should put it in first, what if you love it so much you decide to keep it!
Old Jun 17, 2007 | 12:19 PM
Pearl96Max's Avatar
I have ideas for it, either way its Alot of work...
Old Jun 17, 2007 | 12:39 PM
nismos14's Avatar
§è~® f®ÈÄk
True........
Old Jun 24, 2007 | 04:10 PM
nismos14's Avatar
§è~® f®ÈÄk
Old Jun 24, 2007 | 04:45 PM
Vewy vewy nice.........
makes me want to upgrade.....at least a little to the 7100 from my current unit...
Old Jun 24, 2007 | 04:56 PM
Pearl96Max's Avatar
meh I still like mines better.
nismos14's Avatar
§è~® f®ÈÄk
Not that many differences though... would it be worth it?
Old Jun 24, 2007 | 04:57 PM
nismos14's Avatar
§è~® f®ÈÄk
Thats ok, I cannot and will not compete with you.
Old Jun 24, 2007 | 05:03 PM
What a show off.....
Same thing I was thinking...but......
Old Jun 24, 2007 | 05:30 PM
Pearl96Max's Avatar
But you can always try.
Old Jun 24, 2007 | 07:05 PM
nismos14's Avatar
§è~® f®ÈÄk
No, I cannnnnnnnot lol
Old Jun 24, 2007 | 07:54 PM
Pearl96Max's Avatar
Wus
