audio capacitor help
Old Jul 22, 2007 | 09:46 AM
goldfish914's Avatar
so i have a pair of subs hooked up with my amp and i followed a diagram from rockfordfosgate on how to put a power acoustik capacitor into my system. it works and i charged it beforehand but the only thing is it keeps charging after my car is off and it drains my battery. i have a feeling its because i used the power source from my battery instead of my cigarette lighter fuse (both of which are going to my amp) im kind've a noob w/ audio i can hook it up and thats about it im not sure why there are two (+) wires going to my amp and i just followed directions. any help with connecting my capacitor correctly?
Old Jul 22, 2007 | 10:02 AM
WhiteA32's Avatar
A cap is like a band aid it just hides the underlying problem which in this case is your ground. Get rid of your cap and search for "The Big Three" and do that.
And how many watts are you running anyways....
tong's Avatar
um yeah. one + is for constant power (meaning directly to the battery) the other is the remote turn on, a source of power that only turn on when the stereo is on, --- POWER ANTENNA is a perfect one for this, that way your amp shuts off when your car is off, that's y your battery has been draining. Hope this helps.
Oh how did you charge the cap b4 hand?
Old Jul 22, 2007 | 08:48 PM
the capacitor can handle the watts im not sure how many off hand b/c i bought it all 2gether but i charged it w/ the resistor in place of the fuse until it reached my car battery's volts. do i want to use the other power source which would be the power source from my cig lighter? this is controlled by a kill switch by my feet.
Old Jul 23, 2007 | 06:46 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
power antenna isn't always the best remote turn on b/c some head units turn off the power antenna once you stop using the radio and switch to another source, i.e. cd.
Old Jul 23, 2007 | 06:54 PM
here's a quick sketch of how to quickly wire up your system with a cap.
there shouldn't be two power wires going to your amp.
Old Jul 24, 2007 | 07:54 PM
maximal's Avatar
actually, some of my fosgate amps have 2 power inputs...you could either connect both from the battery, or one from the battery and one from a cap.
Old Jul 24, 2007 | 08:00 PM
viperxiv's Avatar
There's a blue wire coming out of your wiring harness behind your CD deck, that's a good remote wire.
Old Jul 25, 2007 | 06:11 PM
huh...didn't know that. you learn something everyday
Old Aug 2, 2007 | 09:34 PM
i used that same wiring diagram and there is only one (+) supply 2 the cap which acts as the output too... how do i make the capacitor shut off when my cars not on?
Old Aug 10, 2007 | 05:40 PM
jkmay01's Avatar
Lil 8
the caps main purpose is to supply a instant source of current to demanding amps. specifically sub amps since they generally have large current draw. the cap as spark splug's diagram indicates is correct. your cap only charges until it is full then waits to discharge when that deep bass hits and quickly re-charges for the next current demand. it wont pull voltage unless your radio and amps are still on.
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 20, 2015 10:20 PM
popdedop
Sep 11, 2015 11:17 AM
