Question about head unit
Old Aug 1, 2007 | 08:24 AM
Cashj2002's Avatar
What would cause the amp not to come on, and the speakers inside the car not to work? The radio has power and the amp doesnt run the speakers...
Old Aug 1, 2007 | 08:28 AM
kpr10is's Avatar
The remote turn on wire not being connected properly...
Old Aug 1, 2007 | 05:39 PM
viperxiv's Avatar
If one of the magnets of the speakers is in contact with the body of the car nothing will work either. That would only be the case maybe if you just installed speakers.
Old Aug 1, 2007 | 07:21 PM
DcMaN's Avatar
viperxiv what the hell are you talking about lol. Thats completely false... Definatly sounds like the remote turn on wire 100%. Or a maybe a fuse is blown? Or maybe even the ground is loose ?
Old Aug 1, 2007 | 07:32 PM
shyheim07's Avatar
all in all, checkk yuh blue turn on wire, grounds to amp
Old Aug 1, 2007 | 09:26 PM
Pearl96Max's Avatar
I tend to get a bit irritable
LMAO With all due respect, did you just pull that out of your ass?
Old Aug 1, 2007 | 09:52 PM
filtor1's Avatar
I quadruple the remote lead wire theory.
Not sure what a speakers motor being stuck to the car door would do though. :dunno:
filtor1's Avatar
Oh wait, it would do nothing.
Old Aug 2, 2007 | 06:56 AM
freshv6power's Avatar
You have to check all the wiring connections to the amp:
1) the remote turn-on wire(at both the headunit and at the amp)
2) the 12+ wire coming from the battery (and it's fuse)
3) and the amp ground wire (at both ends)
You can use a multimeter to check all of these.
If all of those check out, then you can swap in another amp to check if the one you have is blown. Also there might be a fuse on the amp itself.
Oh, if the amp is turning on but there is no sound, make sure the rca cables didn't come loose at the headunit or at the amp.
Old Aug 9, 2007 | 04:08 PM
Matt93SE's Avatar
STFU n00b!
If the motor somehow gets shorted to the voice coil- and thus speaker lead- you can do some nasty sheit.
some older head units used chassis ground as one speaker lead, and the other swung +- from there. weird system, ugly electronics when you try to repair.
they've gone to a differential amplifier system now where each lead swings +- in relation to each other and things are much better off.
but...... ever accidentally touched a speaker lead to the chassis when the amp is powered up? My old Orion HCCA250 welded an 8 awg speaker wire to the floor of the car one time. ouch.
now translate that to a bad speaker with a voice coil that's shorting against the motor assembly somewhere, and you have one nasty mess. been there, done that, fortunately I had a fire extinguisher in the garage when it happened.
Old Aug 9, 2007 | 04:18 PM
nismos14's Avatar
§è~® f®ÈÄk
Did that happen in your badass charger
Old Aug 10, 2007 | 12:04 PM
Matt93SE's Avatar
STFU n00b!
heh... not my charger. I just like the hideousness of it so I stole the pic from fleabay.
it happened in my old mitsu truck. back in the day when you weren't cool unless you were breaking windows. I had six 10W6s behind the seat (in a regular cab mini truck! good thing I have short legs!) powered off that one amp. paid of 6.5s in each door, each fed by another 250HCCA and the tweets run by a 225HCCA.
Poor 90hp engine only had a 45amp alternator on it... took two batteries and a huge stack of capacitors to keep the engine running when I had it cranked up.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
