So will this setup work?
Old Jul 20, 2001 | 07:18 PM
Nick97SE's Avatar
Subwoofers: 2 12" JL Audio W3-D4
(I might be getting 10"--I'm undecided on size right now! )
http://www.jlaudio.com/subwoofers/12w3.html
Amplifier: JL Audio 250/1
http://www.jlaudio.com/amps/2501.html
A friend told me that if I get the D4 (dual 4 ohm voice coils) that I can run the voice coils in parallel so that each sub will get 250 watts continuously from this amp. I just want to make sure it will work before I go out and buy this stuff.
Thanks!
-Nick
Old Jul 21, 2001 | 05:23 AM
Micah95GLE's Avatar
Yeah, it'll work, but the power will be on the low side. The amp will supply only about 300 watts to both subs. You might want to consider a more powerful amp, or use one 12W3-D2 on the 250/1.
Old Jul 21, 2001 | 11:38 AM
Nick97SE's Avatar
Correct me if I'm wrong here, but wouldn't 300 watts be more than enough power for these subs? They handle 250 watts continuously, so giving them 300 should run them sufficiently. I could be wrong here...I don't know much about this stuff.
Thanks,
-Nick
Old Jul 22, 2001 | 04:45 AM
Dahnryman's Avatar
jl amps
they do underrate these amps a bit....the 500/1 is made for the 12w3s it will give you about 146 db in a sealed box in the trunk with just the ski hole open...i just got the 500/1 and it does do what it says...i picked mine up for 345... sorry guys this deal was one time only from a good friend....just for luck in getting one cheap...ask to buy the display model...they are usually about 25 to 50 percent off
Old Jul 22, 2001 | 08:44 AM
Nick97SE's Avatar
Thanks Dahnryman!
I've decided to use the JL Audio 500/1 with 2 10" JL Audio W3 Subwoofers.
Now, if I could only settle on some good speakers.
-Nick
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
cruce91
Sep 20, 2015 10:23 AM
Hailstatejig
Sep 2, 2015 06:52 AM
