THE Audio thread ! 06/07/08/09/10/11/12/13ers move along..
Old May 15, 2009 | 10:39 PM
  #4881
AscendantMax's Avatar
yeah not much whoring now-a-days
Old May 16, 2009 | 12:21 AM
  #4882
Fast1one's Avatar
I never whored that much, but I enjoyed the audio talk. I can start talking home audio My home rig is KICK ***
Old May 16, 2009 | 10:21 AM
  #4883
go for it, nobody said this thread was strictly car audio....or audio for that matter
Old May 16, 2009 | 10:38 AM
  #4884
BLACKonBLACK98's Avatar
Former Vendor
Originally Posted by Fast1one
1. Newb. The bottom unit is NOT a HU, its the controller to the H701. If you have been under a rock, its one of the most capable/versatile processors ever made and is now discontinued.
how about the jvc in dash and the cd7200? that equals 2 right? newb.
trunk is super sick. love the idea.
Old May 16, 2009 | 11:40 AM
  #4885
Fast1one's Avatar
I see no such unit Whooooops!
Old May 16, 2009 | 11:52 AM
  #4886
Fast1one's Avatar
Sure :-D In chronological order. Development thread here: http://www.diyaudio.com/forums/showt...hreadid=142155
Originally posted by Fast1one
I went ahead and got everything hooked up...
First of all, the FF85KeNs sound absolutely phenomenal. I haven't been listening for long, but one thing is for sure that these things are VERY revealing. I was expecting them to have this characteristic, but not at this level. I'm not completely sure if I want to keep them yet simply because they have brought out the worst of mediocre recordings in my collection. I am not quite ready to simply abandon half of my music
They have an incredible sound stage. Also very good micro and macro dynamics for such a tiny speaker. In addition, they are not fatiguing or do they have the imfamous fostex "shout" that I have heard about. Extremely smooth sounding, and I suspect its because of Dave's treatment. Also, suprisingly they handle genres like rock very well.
He wasn't kidding when he said they can rival quality tweeters. They definitely have wonderful sparkle to them, and nothing seems to be missing on the top end.
As far as the woofers go. I definitely need more power in the future. Currently they are each receiving only 30 watts each. I will be upgrading eventually to 100 watts each for head room. The FRs don't seem to be straining at all at higher levels with the 400hz crossover point. The woofers have great bass with a little EQ, enough for my tastes. Cone movement is controlled with music, only reaching about 2-3mm P-P with heavy bass passages.
However, they do leave a bit to be desired on the top end. Crossing them over above ~150hz simply doesn't sound very good. So right now I have a small gap in the frequency response. Not too big of a deal for my tastes. Over all the performance of the woofers is very good for the price, with great impact. The higher crossover point doesn't really steer the sound stage down as many led me to believe.
One more thing I forgot to mention. They are currently operating WITHOUT the wings because of a mistake I made when cutting. Being a college student, I only had access to a circular saw and router. I got a little careless with the circular saw and screwed up on one of my cuts. Needless to say I didn't have any more wood. However, I like the configuration very much and will likely keep them wingless for now.
I am currently listening to the self titled album Nouvelle Vague. Bossa Nova music...Her voice is absolutely beautiful.
Here are some quick pictures I took. They are currently in my bedroom until I make room in the living room
These woofers are definitely sounding better by the hour. I gave them a little exercise while I was at the library studying for about 6 hours with a 15hz test tone at low volume.
I don't think the crossover point is going to budge for now. Currently its set at ~140hz and I am enjoying the blend they have with the FRs. I don't really feel like I am missing much from the recording in that range. After all, its a crossover not a brick wall
Also, the bass is really nice even with no EQ. I haven't played anything that really made me miss deep bass yet. Even playing Pink Floyd's "Dark Side of the Moon" album was quite satisfying from beginning to end. The track with the clocks going off (Time?) is eerily life like. "Money" also has that same quality with all the registers going off in the beginning.
I think I may have some wiggle room as far as the FF85s go. They don't really move at all even with heavy music crossed over at ~350hz now. I will slowly bring the crossover point lower once I am confident that I they have the mechanical head room.
One final note for now. I think I am going to end up keeping the Fostex and just listen to good recordings with them. After all, I have other rigs for the rest of my collection ( *cough* car).
UPDATE
First off, I upgraded to two Dayton plate amps, which do 170 watts at 8 ohms and 240w at 4 ohms. I spent a couple hours doing some minor modifications to the bass drivers. I did two things:
1.) I added some Cascade Audio engineering VBMAX sound deadening to the frames. A car audio vibration dampener Being stamped steal, they had a significant amount of ringing to them. I added some to all the spokes and added some around the perimeter where the magnet joins the frame. Just knocking it with my fist I could I already tell it was going to make a big difference; Very solid and no ringing whatsoever. I started playing music and WOW. What a difference, the upper response (150hz+) of the drivers was cleaned up quite a bit to my ears. Was surprised at how significant it was. DEFINITELY recommend it! This should be the very first thing you should do before you even play them. But this was only part of the equation. I turned off the music and did the following.
2.) I added 10 ohms (two 20 ohm 20 watt resisters in parallel) in series with each driver. To raise QES, and therefore QTS.
All I can say is, WOW. HUGE difference. Before since there as a rising response, it really brought out the worse of the Pyles, particularly when crossed over high as previously mentioned. Now that the bass is more full and extended (easily to ~40hz to my ear), the pyles sound MUCH better and are now crossed over higher at about 160-170hz with no issues. Interestingly enough, I found my self pushing them a lot less, mechanically, since the presence of the low end allowed me to turn the gain down. Not to mention the amplifiers are now running a at 8 ohms, so they run cooler.
WONDERFUL macro and micro dynamics , dear God this is music. Eric Clapton Unplugged in particular was breath taking. The speakers are complete. Or should I say, what speakers? They completely disappear into the room!
Cheers!!! Long live music!
Old May 16, 2009 | 01:37 PM
  #4887
djfrestyl's Avatar
Suspension Yoda
Ya, I noticed that when I looked at the model # a little closer. Oops.
edit: lol @ calling me a noob. Quite the opposite.
Old May 16, 2009 | 03:52 PM
  #4888
Fast1one's Avatar
I know you're not a noob, I was just messing with ya
Old May 17, 2009 | 09:24 AM
  #4889
i've always wondered how those setups sound like. is there any issues of the backwaves causing interference with no side baffles?
Old May 17, 2009 | 10:13 AM
  #4890
Fast1one's Avatar
Actually the side baffles increase low end extention at the cost of ripples in the upper midbass response and a loss of efficiency. Its called a U-baffle. Just for bass. So they are not really needed...
The amount of extension from the bass drivers is dependent on the area of the baffle. That's why its so big. Dipole setups sound like they do BECAUSE of the back wave. Without it, it wouldn't be dipole. There has to be sufficient spacing to the back wall to work properly, usually on the order of 1m or more, which is what I have.
Since there is no enclosure, the music is very pure and natural sounding, with no colouration whatsoever. Since the back wave is delayed, the result is ambience, giving a sense of spaciousness which is non-existent in regular boxed speakers. Finally, since the bass speakers radiate in dipole form, room modes ( or areas where there is severe bass cancellation and ripples) are vastly reduced. Usually this is the biggest problem in rooms and the most difficult (expensive) to solve.
Obviously the down fall is for lower frequencies, you need a lot of cone area to compensate for the lack of a box. Think Infinite baffle. However, since higher QTS drivers exhibit more favourable (IE extended) response in a dipole, and since higher QTS drivers are generally less expensive ( weaker motors) this isn't particularly difficult to achieve. Two 15s are sufficient, I have four for headroom
Hope that answers some questions. You should try it with some cheap speakers. Wood is cheap
Old May 18, 2009 | 08:31 PM
  #4891
Fast1one's Avatar
Bueller? LOL...
Old May 21, 2009 | 11:02 AM
  #4892
lots of maximas here in the boston area. i wish houston would have more of this nice weather in the summer.
Old May 29, 2009 | 06:23 PM
  #4893
djfrestyl's Avatar
Suspension Yoda
This thread has started to suck.
Old May 29, 2009 | 06:24 PM
  #4894
djfrestyl's Avatar
Suspension Yoda
Busy day for me tomorrow:
Precat
ES motor mounts. Mine are definitely shot. I'll post pictures of the old ones. Waiting for the lol'age of those
Radiator
Cleaning
Yardwork.
  #4895
djfrestyl's Avatar
Suspension Yoda
4 more posts to 8K
Old May 29, 2009 | 06:25 PM
  #4896
djfrestyl's Avatar
Suspension Yoda
3.
Old May 29, 2009 | 06:26 PM
  #4897
djfrestyl's Avatar
Suspension Yoda
Mr Weatherman says its going to be 74degrees by noon tomollow - perfect.
2.
  #4898
djfrestyl's Avatar
Suspension Yoda
Old May 29, 2009 | 06:27 PM
  #4899
djfrestyl's Avatar
Suspension Yoda
8000, woot!
This thread has still gone downhill, which sucks
Old May 29, 2009 | 08:47 PM
  #4900
Pearl96Max's Avatar
I tend to get a bit irritable
Interesting !
Old May 30, 2009 | 09:03 PM
  #4901
Pearl96Max's Avatar
Originally Posted by Jreed2008
Wow so this is how you guys rack up all the post .................................... Well just been drooling over JL's new HD 900/5 anybody have a guess at what MSRP will be i'm very interested but think it will b over a G
The other HDs have yet to impress me, so holding my breath for this one to would be suicide.
You do know that Im gonna have to delete your post now right ?
Old May 30, 2009 | 09:38 PM
  #4902
back in houston! damn you northeast people with your mild summer weathers! i left IAH and was greeted by 91 degrees of humid air.
Old May 30, 2009 | 09:39 PM
  #4903
Precat
Radiator
Cleaning
Yardwork.
wanna do my yardwork too?
Old May 30, 2009 | 10:06 PM
  #4904
Fast1one's Avatar
Old May 31, 2009 | 10:05 AM
  #4905
Pearl96Max's Avatar
No Love! The specs look very promising sir, 4 X 100 and a 500w sub channel or 2 X150 and 500w and very compact....But time will tell
Plenty of love, but rules are rules !
Oddly a measly lil Billet 475 (paper say 75 X 4, 150 X 2) kicked the ever living crap out of my clients PDX4.150. Go figure ...
:sigh: deleting again...
Old May 31, 2009 | 08:38 PM
  #4906
not a tough crowd...but it's simply this thread's rules.
Old May 31, 2009 | 08:44 PM
  #4907
djfrestyl's Avatar
Suspension Yoda
Nope. Got too much of my own to do.
Old Jun 2, 2009 | 09:02 AM
  #4908
this thread is starting to fail.
Old Jun 2, 2009 | 09:03 AM
  #4909
anyone traveling this summer?
Old Jun 2, 2009 | 10:09 AM
  #4910
djfrestyl's Avatar
Suspension Yoda
Trying to. Likely internationally, not sure where.
You?
Old Jun 2, 2009 | 10:19 AM
  #4911
nismos14's Avatar
§è~® f®ÈÄk
I'm no.
Old Jun 2, 2009 | 02:55 PM
  #4912
You?
just came back from the northeast a few days ago. the gf and i thinking about driving down to orlando. but that idea is still high in the air. if we do, i'll go harass chris or something.
Old Jun 2, 2009 | 03:04 PM
  #4913
The Law's Avatar
I R The Law
I'm going to New York in 2 weeks
Old Jun 2, 2009 | 03:09 PM
  #4914
djfrestyl's Avatar
Suspension Yoda
Whereabouts? Our neck of the woods?
Orlando = no beaches. Do Ft. Lauderdale/Miami instead.
Old Jun 2, 2009 | 03:13 PM
  #4915
djfrestyl's Avatar
Suspension Yoda
Don, RUN. Far far away.
Old Jun 2, 2009 | 03:18 PM
  #4916
The Law's Avatar
I R The Law
HAHAHAHAHAHHAHAH!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 2, 2009 | 03:23 PM
  #4917
djfrestyl's Avatar
Suspension Yoda
(I'm practicing what I preach, I only live 15 minutes from him.)
What're you coming this side for? The good weather is by you...
Old Jun 2, 2009 | 03:31 PM
  #4918
The Law's Avatar
I R The Law
I was going to come bearing gifts too, oh wells
I'm going on vacation with my family. Going to Washington DC to tour the white house then stay at my aunt's place in NY for like 5 days.
Old Jun 2, 2009 | 03:40 PM
  #4919
djfrestyl's Avatar
Suspension Yoda
Hope you're doing more than the White House, there's plenty of cool sht to do there.
Old Jun 2, 2009 | 03:49 PM
  #4920
The Law's Avatar
I R The Law
In DC or you mean in NY? Well we're only going to be in DC for 2 days at most.
