2 questions? componemt tweeter & RCA cables
Old Aug 31, 2001 | 09:36 AM
pjalst
I have two question to ask
1) where are you guys/gals installing your component
tweeters on the 4th Gen? on the door, dash or, the
plastic trianle by the side view mirror?
2) I will be installing a new HU, I don't have the $ yet to
ungrade the whole system. later I want to ad an amp and
subs to the system. Question, when installing the new HU
should I run the RCA cables for the amps at this time,
not attatching it to anything? or, should I NOT be lazy
and remove the center console again when I do install
the amp? Will leaving the cables unattatched cause a
problem?
Old Aug 31, 2001 | 02:06 PM
mb1's Avatar
mb1
I'm in the same boat as you with the head unit. What I did is when I installed mine, I ran all the wires from it: 2 sets of RCA's and the remote cable (dont forget that). That way I can just throw everything in without having to disassemble the dash again. The tweeters I'm probably going to put in the same location as the stock ones in the SE's and GLE's. Hope this helps.
Old Aug 31, 2001 | 02:32 PM
pjalst
I have a GXE, it doesn't come with the separate tweeters
Old Aug 31, 2001 | 03:11 PM
jmax
My tweets are in kickpanels. So none of the above choices applies.
Old Aug 31, 2001 | 10:56 PM
mb1's Avatar
mb1
I have a GXE also. I will make holes in the same place as the stock tweeters come in.
Old Sep 1, 2001 | 08:37 AM
jiaxima96's Avatar
Me too GXE. I'll probably install them in the mirroe triangle plastics. The only reason is in case I screw it up, it will not cost much to get another piece.
Old Sep 7, 2001 | 09:20 PM
Jaybird180's Avatar
Hmmmm....can anyone tell me if they will fit my 3rd Gen?
Old Sep 8, 2001 | 07:49 AM
Shugarhi's Avatar
[B]I have two question to ask
just a tip, keep the tweeters closer to the larger speakers or else you will get some separation and they will not sound as good
Old Sep 8, 2001 | 09:07 AM
Jaybird180's Avatar
Rockford says ideally they should be within 2", but if not then they should be further than 7".
Old Sep 8, 2001 | 07:24 PM
pjalst
So, the triangle plastic piece by the sideview mirrors will be to far?
Old Sep 9, 2001 | 09:19 AM
Jaybird180's Avatar
No, the sail is FURTHER than 7". So it meets the recommendation.
knight_yyz
Oct 24, 2015 08:05 AM
95naSTA
Sep 21, 2015 06:50 PM
pktaske
Sep 4, 2015 08:40 AM
