audio experts ...need confirmation
Old Sep 11, 2001 | 10:35 AM
93 SE's Avatar
if a 4 channel amp (good amp lets say) is rated 100x4 watts at 2ohms ....it would require me to have (2)4ohm speakers wired in parrallel per channel ...correct...now all in all this means i could have 8 total speakers running at 100 watts each ...or is there something im missing...
Old Sep 11, 2001 | 03:00 PM
mb1's Avatar
mb1
Your two speakers on each channel will split the power output, so each speaker will get 50 watts.
Old Sep 11, 2001 | 04:08 PM
93 SE's Avatar
is this safe to do ..i never seen anyone put 8 speakers to an amp...will the amp handle this
Old Sep 11, 2001 | 07:09 PM
mb1's Avatar
mb1
If the amp can handle two ohms then it shouldn't be a problem. Make sure you provide adequate power to it. People put 8 subs to mono amps without a problem(if they know what they're doing).
Old Sep 11, 2001 | 08:29 PM
max'n out's Avatar
wheather or not the amp can handle it is up to the amp...which amp do you have? 8 subs on 1 amp with on ly 100x4 @ 2ohm's prob ain't the best idea. Your gonna split the power so much the sub will be way low on power and you not gonna get the output you think you will.
Old Sep 11, 2001 | 08:38 PM
93 SE's Avatar
not subs....speakers....but i probably wont do it now since i will only end up getting 50 watts per speaker...its an autotek ss400.4,says 1 ohm stable
Old Sep 11, 2001 | 08:57 PM
max'n out's Avatar
I asume then that your gonna run the midbass in parrell and that you have seperate midrange and tweets?
Old Sep 12, 2001 | 07:31 AM
mb1's Avatar
mb1
I was just checking out the specs of your amp. I noticed that the 100x4 is with 14.4 volts. at 12 volts (which is what you have, unless you upgraded your electrical system) it puts out 87X4 RMS. You will not be getting the full 100x4. Also the amp is stable down to 2ohm mono which is good for a 4 channel amp, most can only do 4ohm mono, so it shouldn't have a problem pushing 8 speakers. If you are just planning on powering some componenets or coaxials, and are not a big music fanatic I say go for it. It should work fine.
Old Sep 12, 2001 | 01:08 PM
Dustyroads's Avatar
Ummmmm.....the reason they list two voltages is because your car can see 2 different voltages. When the car is running there is 14.4volts and when it is off you only get the 12volts. No upgrading is necessary. Just letting the guy know he doesn't have to upgrade to get what he already has.
Old Sep 12, 2001 | 01:16 PM
93 SE's Avatar
so when my car is running i get 14.4 or 13.8 volts and when the car is off i get 12....
Old Sep 12, 2001 | 01:18 PM
mb1's Avatar
mb1
The car doesn't see two different voltages. Most companies rate their amplifiers at a higher voltage because the output looks better on paper. You car is supposed to have a constant, I believe 12.6 or 13.6 volts one of those. I never said he has to upgrade, I just let him know he will not get the full 100x4 watts.
Old Sep 12, 2001 | 01:54 PM
max'n out's Avatar
Acually when the car is off you have around 12.4 to 12.7 volts depending on the cars charging system and battery. When you drive the car it can go up to around 14.4 but will ave at ave speed around 13.8. Again all depends on the charging system.
Old Sep 12, 2001 | 08:34 PM
mb1's Avatar
mb1
Yes you are right. I was typing in a hurry. I meant the differnce between a running car and a stopped one is not as big as 12.0 to 14.4 volts. Lets get back to the topic: can he run 8 speakers? yes. Will he get 50x8 watts? probably not. But having 30-40 clean RMS watts to each speaker should work just fine for him. It is mutch more then any headunit can put out.
Old Sep 12, 2001 | 08:46 PM
max'n out's Avatar
Running 8 speakers with one amp physically dectates that he will not get 100 watts to each. Can he do it yeah. Should he...it depends on the plan. So with that said what is the EXACT plan.
If you plan to run 4 midbass 2 midrange and 2 tweets with passive x overs it will be fine. If however you just run a bunch of mid's together it's not gonna work.
Old Sep 12, 2001 | 09:00 PM
mb1's Avatar
mb1
just curious, why wouldn't a bunch of mids work?
Old Sep 12, 2001 | 09:10 PM
max'n out's Avatar
Because any sound wave above 300 hz is directional...with midranges is different locations will cause a distortid image..meaning you will get "dealy" or "reverb" (are the best discription type words) similar to sound coming from alot of locations...it would be louder becuase you double the cone area if thats what he is after...but the sound would just be odd. Unless he takes massive and I do mean masive time to place speakers in very well placed locations with time delay,phases, and power properly adjusted crossover point etc. it woun't be right. It's prob not fair to say "it woun't work" It could but takes a whole lot.(Bobby Hilgardner has alot of speakers)and he took well over 200 hours to make it work i can assure you. And from what ive seen on here i dont think we have those kind of people...but i could be wrong,maybe we have alot of people like that.
Old Sep 12, 2001 | 09:20 PM
mb1's Avatar
mb1
Oh, I thought you meant that it wouldn't work period. I agree, there is no need for eight speakers unless they are components.(4 midbass + 4 tweets) Or if you like to listen to your car stereo while you clean your house.
litch
123
Jan 4, 2024 07:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
