question for 5th geners
Old Oct 4, 2007 | 05:35 PM
ghostridden's Avatar
aight how'd yall overcome nissans crappy trunk design, as far as how puttin a sub in the trunk will sink into the spare tire, i was thinking about cuttin me some plywood for a new trunk floor, but then i'd ruin being able to get my spare tire
another problem is, WHAT THE HELL IS RATTLIN lol i've solved some of the problem, only other thing i can think of doin is taking some dynomat and put it on every thing i can see, and another question is, what is it that rattles worse when the rear seats are up
oh and there is a rattle just going down the road with the seats down but no music, just sounds like something loose but i can't find it, anyone else had this annoying problem, if so what the $#%@ is it
Old Oct 5, 2007 | 09:24 AM
arkainshadow's Avatar
i actualy cut out a large piece of mdf to fit the floor of my truck (made it perfectly flat.) it weighs a bit but made a nice flat floor. then i cut a hole in the middle and made a removable door so i can get the spare out. that crapy stock spacer for the spare well was crap and bent inwards from all the crap i lug around. screwed the box into it and doesnt go anywere.
Old Oct 5, 2007 | 10:09 AM
filtor1's Avatar
My box pretty much takes up the entire trunk. I have never had an issue with it moving around on me.
As for the rattles, after spending more than I spent on my front components on deadener and other solutions only to have another bad rattle arise, I gave up. I have well over 260sq ft of deadener throughout the car and my rear deck still rattles. I figure I did the best I could with the money I had, over $900, and decided to cut my losses and deal with them.
Old Oct 5, 2007 | 11:29 AM
burnurass's Avatar
Get this....no more saggy TRUNK!
http://forums.maxima.org/showthread.php?t=357978
Old Oct 5, 2007 | 11:53 AM
The Law's Avatar
I R The Law
My system build/design > any 5th gen design
Both practical and still have trunk space. Oh and no saggy trunk board FTW!
Old Oct 5, 2007 | 11:54 AM
nismos14's Avatar
§è~® f®ÈÄk
There's better, and you have like 1/3 trunk space. What are you smokin.
Old Oct 5, 2007 | 11:55 AM
The Law's Avatar
I R The Law
I still have trunk space, but then again I don't use my trunk much anyways. Plus mine looks better than a rectangle just sitting there.
Old Oct 5, 2007 | 11:59 AM
nismos14's Avatar
§è~® f®ÈÄk
Least you can throw stuff in there and not damage anything.
Old Oct 5, 2007 | 12:03 PM
The Law's Avatar
I R The Law
Yeah that is true. I also have a piece of plexi glass infront of the subs so nothing can get in.
Old Oct 5, 2007 | 01:37 PM
i'm probably going with the mdf board for the floor, though it will add some serious weight to the car, as for the rattles thats kinda disheartening, i've never heard a damn car rattle so bad, even with no bass on, the rear deck is terrible in the 5th gens, i think it has something to do with the pop rivets that hold it down, that was a dumb idea personally
Old Oct 5, 2007 | 01:48 PM
as far as the rear deck goes, im lucky myn doesnt rattle, but what a friend of myn did was, he took foam from a matrise pad and put it between the metal and the top of the rear deck. no more rattle. i believe he said it was a pain in the *** to do tho.
Old Oct 5, 2007 | 02:31 PM
The Law's Avatar
I R The Law
Do you know how to spell? Its "mine" not "myn"
Old Oct 5, 2007 | 02:51 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Thats cause you have a bandpass.
Pearl96Max's Avatar
Not on teh interwebz
Old Oct 5, 2007 | 02:52 PM
Pearl96Max's Avatar
Much better and more efficient has been done. Wake up n00b !
Old Oct 5, 2007 | 03:33 PM
The Law's Avatar
I R The Law
I still doesn't see a point in trying to argue with you guys about it being not a bandpass. Cause for some reason you guys can't get it through you thick skulls. Then again I could careless what you guys say anymore about my system as I know what it is and it isn't a bp thats for sure.
Old Oct 5, 2007 | 03:38 PM
nismos14's Avatar
§è~® f®ÈÄk
Can you PLEASE explain how a sealed chamber and a ported chamber in the same enclosure does not equal a bandpass?
Old Oct 5, 2007 | 04:44 PM
Pearl96Max's Avatar
Your absolutely right, Ive been doing this longer than you have been breathing air, what do I know?
Its not a bandpass because you and your friend said it's not. Thats good factual data there !
Old Oct 5, 2007 | 04:52 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
actually, it looks more like a "bass reflex" enclosure
Old Oct 5, 2007 | 09:50 PM
hi-tek22's Avatar
ive got the board cut out as well
Old Oct 6, 2007 | 05:36 PM
playboi21617's Avatar
your system is clean in the trunk who did that how much did it cost
Old Oct 6, 2007 | 06:24 PM
merovi's Avatar
I have a single 12" enclosure. What i did was make a cut out of wood for basically the entire trunk layout. I cut it in half and put another board under the 2 to try and hold them together. I am able to remove half of the board when i've needed to remove my spare. Little bit of a pain thats the decision u make when u put something like that in your trunk.
Old Oct 6, 2007 | 10:38 PM
yea i figure i'll worry about the spare when the time comes until then i'll build the floor cause the sub is almost firing down cause it sags so bad lol, and as for the rear deck i was thinking about putting something between it and the metal to keep it from rattlin against the metal, which i figure is the worst of the rattle
Old Oct 6, 2007 | 11:31 PM
DcMaN's Avatar
Old Oct 7, 2007 | 08:16 AM
djfrestyl's Avatar
Suspension Yoda
Thanks Jeff for telling people what they should be doing/purchasing.
Details can be found in link in sig.
Old Oct 7, 2007 | 09:46 AM
1996blackmax's Avatar
I have the setup above in my 96 Maxima and it has worked out nicely. I have been kind of able to get away without it in my 02.
This is how my sub looks in my 5th gen, it's kind of angled downward a bit and the back of the box goes up to the rear of the back seats (this give me enough room in front of the box to pull out the cheap board that Nissan supplies if needed). I used L clamps to hold the box in place, three on top and two on the bottom towards the back of the box. I had though about ordering another board from Nilesh, not because of my sub box, but because I sometimes carry a good amount of gear in my trunk. I can put as much stuff as I want in my 96 his board with no issues.
Old Oct 7, 2007 | 10:47 AM
how hard was it to build this type board like you did?? and are those subs and good, i've been looking about just going with something different instead of fixing my arc audio sub
Old Oct 7, 2007 | 11:09 AM
djfrestyl's Avatar
Suspension Yoda
Took a decent amount of time, design, and measuring to get it just right. Then it was just a matter of getting the process right to mass produce them, as I still do now.
Love the subs. Super crisp, get loud when I need it, and they're 10's so I still keep plenty of trunk space.
YOU should definitely buy one of my boards
Old Oct 7, 2007 | 11:36 AM
MacAlert's Avatar
Nilesh, did you secure the box to the board?
Old Oct 7, 2007 | 12:34 PM
seby86's Avatar
does anyone have a powered sub (like an infinity or bazooka) neatly mounted on the side of the trunk? thats wat i'm interested in, i'm past the 12's stage.
Old Oct 7, 2007 | 01:02 PM
how much those subs cost and where from and how much is the board cause i think i just might be gettin one
Old Oct 7, 2007 | 01:07 PM
nevermind i looked at the link in your sig, so is it $65 shipped for both the board to mount the sub and the spare tire cover with carpet??
and if ya could point me towards where to find those subs
Old Oct 7, 2007 | 01:41 PM
You may be able to pick them up from a guy lurkes around these parts once in a while.......
Old Oct 7, 2007 | 03:30 PM
djfrestyl's Avatar
Suspension Yoda
Box is not secured to the shelf, it's got enough weight with the amp mounted to the back, plus the friction from the carpet, that it doesn't move at all, ever.
djfrestyl's Avatar
Suspension Yoda
I don't recall what I paid for them, I've had them for a while.
Old Oct 7, 2007 | 03:33 PM
djfrestyl's Avatar
Suspension Yoda
The carpeted spare tire cover is $70 shipped. Keep in mind that $20 of that goes in shipping alone. You can save $10 if you go with a non-carpeted spare tire cover.
If you want the 'shelf' that the sub box sits on, cut two 6" lengths of a 2x4, and a 6" x 30" piece of plywood (or MDF, or whatever). Screw the 'blocks' to the trunk floor, screw the plywood to the blocks. Done.
I got the subs from Don, Pearl96Max.
SOMETIMES you might find him online, on this very board, in this very subforum.
Old Oct 7, 2007 | 04:25 PM
MacAlert's Avatar
Whoa, really? Never heard of him before!!
Old Oct 7, 2007 | 05:15 PM
djfrestyl's Avatar
Suspension Yoda
He's a celebrity 'round these parts.
Old Oct 8, 2007 | 09:22 AM
burnurass's Avatar
LET'S not boost his ego even more now.....
Old Oct 8, 2007 | 01:28 PM
filtor1's Avatar
That kinda looks like a bandpass box.
