Dimmer Negative Wire
Old Nov 10, 2007 | 12:07 PM
ZIPPIN's Avatar
Mauja He Mauja
I am installing an after market stereo in my 2003. The aftermarket wiring harness has a orange black wire which reads NEGATIVE DIMMER. I can see that once plugged, it mates with the factory wiring harness to a RED/YELLOW wire. However, I don't know where the wire from the after market harness goes. I searched and someone suggested to ground that wire. If I ground it, I cannot control the dimmer function from the dimmer switch. The A/C lights are on bright, even when I turn on the head lights. The clock does dim. And the speedo lights are not able to be dimmed.
There is one wire from the kenwood HU that is illumination. I have already connected that to the wire from the aftermarket harness.
Anyone know where the wire from the aftermarket harness needs to go, other than grounding it?
Old Nov 10, 2007 | 12:12 PM
nismos14's Avatar
§è~® f®ÈÄk
It can also be conneccted to the illumination wire.
Old Nov 10, 2007 | 01:56 PM
ZIPPIN's Avatar
Mauja He Mauja
I almost did that and then decided against it. For now I am going to deal with not being able to use the dimmer. Next weekend I will re-wire.
gavin68
Sep 18, 2021 12:36 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
