How do you run wire to rear of vehicle?
Old Nov 23, 2007 | 03:03 AM
smitty124's Avatar
This is one concept that I can never figure out. How does one run wires from the front, to the rear of their vehicle so they cant be seen? I want to run better wires for my rear speakers, as well as ones for rear view camera.
I'm driving a 92 Maxima SE
Old Nov 23, 2007 | 03:37 PM
SilverGLE's Avatar
I'm watching you, boy...
1. Get a flathead screwdriver.
2. Carefully pry up the door trim.
3. Run wires so they aren't pinched.
4. Put it all back together.
Old Nov 23, 2007 | 04:22 PM
djfrestyl's Avatar
Suspension Yoda
Though I've NEVER found a need for a screwdriver when popping door jamb trim panels.
Old Nov 23, 2007 | 06:30 PM
WhiteA32's Avatar
Yeah WTF is he talking about...
Old Nov 23, 2007 | 08:45 PM
AscendantMax's Avatar
3rd gen is easy. just remove a 10 mm bolt (iirc, been awhile since i tinkered with my old 3rd gen) and take the kick panels out. then just remove those 4 plastic screw/tab thingies on each door sill and they will pop off. then simply run the wire under the carpet, into the rear.
Old Nov 23, 2007 | 10:08 PM
Maxteca's Avatar
I went over broad withe mine I took out the carpet and seats and ran it under all that.
Old Nov 24, 2007 | 10:56 AM
SilverGLE's Avatar
So, you've never used a flathead screwdriver to pry up the door trim on ANY car... You guys must have fingers of steel or something!
Old Nov 24, 2007 | 02:42 PM
NismoMax80's Avatar
SuPeRmOd
you're supposed to hide those wires
I only have 1 wire running up front. A large red one. but I hided it.
Old Nov 24, 2007 | 02:48 PM
WhiteA32's Avatar
Well I only installed it on my car, my cousins Honduh, and a Cougar...
Old Nov 25, 2007 | 05:18 PM
Pearl96Max's Avatar
I tend to get a bit irritable
No, never. I use the right tools for the job.
Old Nov 25, 2007 | 08:44 PM
2 Da Max's Avatar
Right tools make an easy job
Old Nov 27, 2007 | 10:45 AM
Batxel's Avatar
blah
There's a tool at pep boys that does this all for you. I believe its called and panel puller. It'll also prevent you from braking or scratching the plastic. It makes it fast and easy. Only some one with tiny fingers or killer finger nails wouldn't need any tools.
Old Dec 2, 2007 | 09:55 AM
Semper13's Avatar
+1 on the panel popper. never use a screwdriver. a tool for every job, a job for every tool.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
laparka66
Aug 6, 2015 09:36 AM
