Need help connecting DLS Ultimate A6
Old Dec 5, 2007 | 04:24 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
I purchased a DLS A6 which is a mono amp. the manual says that the outputs are internally bridge in parallel, so you cannot bridge them from the outside.
the manual also states that if you have a 2 ohm dvc sub, you should connect each terminal to each coil. my enclosure does not have 2 sets of terminals.
i'm wondering if it's ok to bridge the coils and present a 1 ohm load to the amp and only connect to one of the amp's outputs to still utilize the full 1200watts.
Old Dec 5, 2007 | 04:58 PM
nismos14's Avatar
§è~® f®ÈÄk
It's one ohm stable righ? Have at it.
Old Dec 5, 2007 | 07:37 PM
yes, it is. im wondering if the amp is pushing all 1200 watts at each speaker output or if i will have to wire each coil to each output (2)
Old Dec 5, 2007 | 07:54 PM
nismos14's Avatar
§è~® f®ÈÄk
Ok don't get confused. The amp is internally bridged, therefor the outside connections are just really splits off the same line, just like if you were to run a dual voice coil sub in parallel.
Old Dec 6, 2007 | 05:51 AM
thanks. that's what i thought, i just wanted someone to clarify it for me.
knight_yyz
Nov 6, 2015 02:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
