2006 nissan frontier directechs..
Old Dec 17, 2007 | 10:25 PM
DcMaN's Avatar
whats up, i have to do a 2006 frontier for a friend, and im wondering if i can use a 1100N because it is ssupposed to be a surprise present for Christmas and would prefer not having a key made, also if you could post the diagrams for this truck i would really appreciate it. Also if the 1100n cannot be used what are my other options that dont require the use of an extra key.
Old Dec 18, 2007 | 09:47 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Send to Printer Close Window
2006 Nissan Frontier DirectWire 2.0 Vehicle Information
Remote Start
Item Wire Color Polarity Wire Location
12 Volts green (40A) + ignition harness
Second 12 Volts
Starter gray + ignition harness
Second Starter lt. green + ignition harness
Ignition white/green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory red + ignition harness
Second Accessory green/yellow + ignition harness
Third Accessory
Keysense black + ignition harness or BCM, pin 37
The BCM (Body Control Module) is to the right of the steering column.
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock lt. green to purple - driver kick or BCM, pin 45
Power Unlock white to lt. green - driver kick or BCM, pin 46
Lock Motor purple 5wi driver kick or BCM, pin 65
Driver Unlock Motor gray 5wi driver kick or BCM, pin 59
Parking Lights (-) N/A
Parking Lights (+) gray + driver kick, harness to rear
Also found red (+) in the trailer tow plug harness to the right of the steering column.
Hazards green - hazard switch or BCM, pin 29
Turn Signal (Left) lt. green + driver kick or BCM, pin 60
Turn Signal (Right) green + passenger kick or BCM, pin 61
Headlight pink (L), red (R) + lights or IPDM E/R, brown 8 pin plug
The IPDM E/R (Intelligent Power Distribution Module Engine Room) is the fuse/relay block in the passenger side rear corner of the engine compartment.
AutoLights
Reverse Light lt. blue + driver kick, harness to rear
Left Front Door Trigger see notes - BCM
The LF door is gray in pin 47. The RF door is lt. green in pin 12. The LR door is pink in pin 48. The RR door is blue in pin 13. Use all four wires and diode isolate each. The BCM (Body Control Module) is to the right of the steering column. On vehicles without power door locks, the driver door trigger is blue in the driver kick panel. The passenger(s) door trigger is red in the passenger kick panel.
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision brown - driver A pillar or BCM, pin 63
Trunk/Hatch Pin N/A
Rear Glass Pin
Hood Pin N/A
Trunk/Hatch Release N/A
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left) N/A
Power Sliding Door (Right)
Factory Alarm Arm lt. blue - driver kick or BCM, pin 8
Meter this wire while turning the key in the driver door key cylinder. This wire will also lock the doors. The BCM (Body Control Module) is to the right of the steering column.
Factory Alarm Disarm red/white to gray - driver kick or BCM, pin 7
Meter this wire while turning the key in the driver door key cylinder. This wire will also unlock the doors with a double pulse. The BCM (Body Control Module) is to the right of the steering column.
Disarm No Unlock
Trunk Alarm Shunt
Tachometer NOT white/green ac any fuel injector
Wait to Start N/A
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense lt. blue 8P radio harness or cluster, pin 6
May not be present on vehicles with base level audio systems.
Brake Wire yellow + brake pedal switch or driver kick
Parking Brake green - parking brake sw. or cluster, pin 31
Horn Trigger brown - horn switch
Wipers gray (L), blue (H) + motor or IPDM E/R, brown 12 pin plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
Immobilizer Bypass Module
Required:
Type:
Part #:
Alternate Part #'s:
Yes
Transponder
XK07
556UW, DesignTech 20402, DesignTech 29402
Notes:
Standard on the Crew Cab. Optional on the King Cab LE and Nismo.
Old Dec 18, 2007 | 09:48 AM
Pearl96Max's Avatar
Not all need a bypass, but a 556U or XK07 would be preferred. Although if you dont have the up[loader for the XK07 Id stick with the U.
Old Dec 18, 2007 | 02:57 PM
DcMaN's Avatar
Thanks Don. I gotta look at the key, im assuming if it has a square "thick" head, it has the immobilizer i was under the impression that it is a standard feature on the Crew Cab, and optional on the King Cab LE and Nismo. Im trying to do this as easy as possible, with out losing a spare key. Your also saying that the xk07 do not have a pre installed firmware ? What if i purchased one from you and you flashed it for me since i know you have the part
Old Dec 18, 2007 | 03:01 PM
Pearl96Max's Avatar
Then you can just use the XK07 with the PKN3 firmware.
Old Dec 18, 2007 | 03:04 PM
DcMaN's Avatar
also when it says
should i just hook up the factory alarm arm/disarm wires and not hook up the power unlock / lock since it seems like the factory ones will unlock and lock when pullsed by the brain?
Old Dec 18, 2007 | 03:24 PM
Pearl96Max's Avatar
You *could* but Id see no reason not to just use the doorlock wires. Factory alarm disarm is not needed in these vehicles.
Old Dec 18, 2007 | 07:54 PM
mendon99's Avatar
tastey wheat
xk07 ftw. they're a little pricey though..
Old Dec 18, 2007 | 07:57 PM
Pearl96Max's Avatar
but def worth it.
Mar 12, 2020 12:06 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
coasterswim
Sep 2, 2015 07:43 AM
