JL Audio or Soundsplinter
Old Dec 22, 2007 | 09:49 PM
FlipCpt45's Avatar
I could get on my hands on a JLAudio 13W7 for about 200 dollars w/ box... or get a Single Soundsplinter rl-P 12 for $280...
Which one would you guys get? The W7 has never been pushed with more than 500... (Only has been powered by a JL500/1), it has only been used in a show car..
I will be powering the sub with a single JL 500/1 V1
Old Dec 22, 2007 | 10:09 PM
1996blackmax's Avatar
I've had an RL-p12 and think it's a nice sub.
For that price though, I would get the W7.
Old Dec 22, 2007 | 10:14 PM
FlipCpt45's Avatar
Actually.. if i was going to go with the Soundsplinter route, i was going to buy 2... and use my 2-12 box, but its only 1cu-in and isnt the SS optimal like a 1.35cu-in?
I have two infinity reference (they look like the kappa perfects, but only handle 350w) and they cant really handle the power from the 500/1, They clack.. or bottom out when i play music with heavy deep bass..
Old Dec 22, 2007 | 10:19 PM
Ideally the RL-p's should have around the cubic space that you mentioned.
Old Dec 22, 2007 | 10:22 PM
FlipCpt45's Avatar
The real question is, will a W7 beat the SQ of a RL-p 12? Two of them that is
Old Dec 22, 2007 | 10:43 PM
I've never had a W7 installed in my car, so I cannot comment on that. What I can tell you, is that I was happy with my RL-p, both in output and SQ. If you want to have some nice SQL, then the two RL-p's sound like a good way to go.
Old Dec 22, 2007 | 10:49 PM
FlipCpt45's Avatar
ah, well im poor lol, its a dream of mine hahah.. i guess ill get the W7 and be happy with it.. the JL500/1 is a very nice amp, i was trying to get my hands on a PPI Art series, the 600watt @ 12.2volts one!!, but the guy that was selling it thought i was just messing with his auction cuz i signed up to Ebay just to try to buy the amp :P
Old Dec 23, 2007 | 12:14 AM
2AZN2DMAX's Avatar
Are you going to buy the 13w7? If you don't want it I will give you $300 for it.
Old Dec 23, 2007 | 08:14 AM
FlipCpt45's Avatar
Yeah probably, its replacing my 2 12s. Sorry
Old Dec 23, 2007 | 10:51 AM
DcMaN's Avatar
dont bother getting the w7 unless you plan on powering it properly.
Old Dec 23, 2007 | 11:29 AM
mendon99's Avatar
tastey wheat
the W7 is a better deal at that price range...
If you have the power, get the W7.
This is about the only time I'd ever suggest JL over SS though..
Old Dec 23, 2007 | 01:24 PM
FlipCpt45's Avatar
Well, it will be powered by a single 500/1 :P, ive heard it in the car, it was in a honda civic, powered also by a 500/1, it was pretty loud..
The rl-P 12, is rated for 500-1000RMS, where as the JL is like 500-1500RMS or something
Old Dec 23, 2007 | 01:53 PM
AscendantMax's Avatar
Owned the RLp 15 for quite awhile now. Pretty good SQL driver that doesn't need a whole lot of power to get loud. I'd say give the RL-p's a try, and it seems like you have the proper box for it.
Also to note, Mike from SS has top notch customer service.
Old Dec 23, 2007 | 06:55 PM
2AZN2DMAX's Avatar
JL says the 500/1 is ok to use but I would suggest using a 1000/1. Better to have more than just enough.
Old Dec 23, 2007 | 08:19 PM
adampit's Avatar
13w7 needs at least 1000 watts to get it moving proper IMO.......
i give around 1300 to each 12w7 right now (i have 2)
Old Dec 23, 2007 | 09:26 PM
FlipCpt45's Avatar
Yeah, well... if i had the money i would have tried to find a better amp than the JL 1000/1 or rather a better amp than the 500/1 i have right now..
I Really like the rl-Ps, but i don't have money to just dish out on subwoofers at the rate of the rl-p's i would be spending like $600+.. I'm just thinking about picking up the W7 because of the price.. only $200? They sell used for like $400, and those are probably not from a show car thats almost never driven, and where as the times I've ridden with him when he decides to take it out, the sub is never turned on/ or the volume is never turned up.
Old Dec 23, 2007 | 09:51 PM
DcMaN's Avatar
and not 1000 watts, 1000 rms is what is reccomended
Old Dec 23, 2007 | 10:22 PM
FlipCpt45's Avatar
....what? When i think about speaker/amp watts, i think RMS. and i also do my research, as you can see up top, i recited the RMS ranges for both the rl-P and the JL13W7.. if i recall correctly, the 500/1 is 500RMS
Old Dec 23, 2007 | 10:33 PM
2AZN2DMAX's Avatar
Sorry, I'm blind I thought it was a 12w7. You really need a 1000/1 to push it.
Old Dec 23, 2007 | 10:56 PM
FlipCpt45's Avatar
Well, is there anything else i could possibly power the 13W7 with, that isnt a 1000/1? Those are pretty damn expensive.
What if i run TWO 500/1s, one to each Voicecoil
Old Dec 23, 2007 | 11:00 PM
2AZN2DMAX's Avatar
Sure anything that has a RMS power of 1000 watts. I am partial to JL b/c they match everything up so well and their specs for each other are right on point, just check their manuals. Any amp will do just have atleast 1000 watts RMS. With the 1000/1 you are getting 1000 watts whether at 12V or 14V ( I love the RIPS System!)
Old Dec 23, 2007 | 11:11 PM
FlipCpt45's Avatar
Yep, ive noticed this on the JL Amps, i rewired my subs from 1.5ohms to 4.5 (my 2 infinity 12s are Eff'd up, their dual 4ohm VC hooked into a 2ohm load, but when i put them in parallel, i get a 1.5 ohm load, instead of a 1ohm) i wanted to see if there was a difference between ">250 Damping Factor @ 2ohm" and ">500 Damping Factor @ 4ohm" Wtf is Damping factor? Isnt it something like, how precise the amp can control the driver? Well, i noticed at 4.5ohm, the sub hits more tightly, than when it was in 1.5ohm, also, my voltage doesn't even flinch a .1 a volt, when its in 4.5ohms
Old Dec 24, 2007 | 05:11 AM
nismos14's Avatar
§è~® f®ÈÄk
Any speaker you get will most likely be a little off of the rated resistance.
Old Dec 29, 2007 | 07:11 PM
bluejays026's Avatar
i would go with a sound splitter. if you got a w7 you would need to get all your windows replaced with high temperate plixy glass.
Old Dec 30, 2007 | 12:38 AM
joebangaa's Avatar
What's sound splitter? And why do all your windows need to be replaced w/ a W7? Go hang yourself.
Old Dec 30, 2007 | 06:55 AM
mendon99's Avatar
tastey wheat
lol ive never heard of a W7 breaking any windows. they are not the end-all subwoofer by far..
Joebanga, take it easy dude
Old Dec 30, 2007 | 07:55 AM
Deep breath once one a while helps take the anger away
Old Dec 30, 2007 | 10:27 AM
FlipCpt45's Avatar
Damn, thats harsh, Well, i guess ill be going with the JL and in the future get a 1000/1 or a USAMP .. and ill just make the infinitys into a house sub with the 500/1 FTW! Anybody know what they use at like Bestbuy to power those amplifiers? I know its a AC/DC Converter, but it doesnt cut out due to low voltage.. hmm
Old Dec 30, 2007 | 12:33 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
did you recommend another subwoofer b/c you believe one was TOO loud?
and 1 13w7 is FAR from powerful enough to shatter a window.
Old Dec 30, 2007 | 04:40 PM
adampit's Avatar
not really man... LOL
to shatter or break a glass window you will have to have enough power and hit the resonant frequency of the glass....
and i have 2 W7's and no problems with my windows nor have any of my friends who have had W7's
Old Dec 30, 2007 | 05:05 PM
That's what I would call adding some hot sauce to the story......
Old Dec 30, 2007 | 05:30 PM
W7s don't really need a whole lot of power to get loud. This guy that went to the local sound meet had only a 500/1 on his 12W7 and it got pretty stupid loud in his car. Install is key too.
oh, a side note. my RLp 15 ported with 1000 watts going to it gets fairly loud.
Old Jan 2, 2008 | 10:09 AM
FlipCpt45's Avatar
ahhh, i just priced quoted a box for a W7, and its like 100-150 so im pretty much going to be spending more than ONE rl-P 12 :P
Old Jan 2, 2008 | 02:01 PM
100-150 isn't too bad of a price for a properly built box. i usually charge 120 for a ported box for a 15.
anyhow, i think you'll be content with the RLp
Old Jan 2, 2008 | 11:43 PM
FlipCpt45's Avatar
I might actually go with the 13W7, cuz at the price, i mean its a very good sub... but not very compatible with anything... i mean 13.5in sub, 3Ohm load... wtf :|, but i dont want the JL just to go to waste, maybe after it, ill just buy some RL-p's and get done with it, and make the JL into a Famtom sub, ono if you've heard of those, the Hometheater version of a 13W7 lol
Old Mar 5, 2008 | 11:42 AM
Donkalion's Avatar
i Would get the JL W7 Hands down!
Old Mar 5, 2008 | 01:09 PM
shyheim07's Avatar
For $200 Billz, get the JL
Old Mar 5, 2008 | 03:18 PM
SS's customer service >>> JL's.
Old Mar 5, 2008 | 04:25 PM
filtor1's Avatar
I want to know where I can get my hands on a couple 13.5's for $200/ea. Sick deal.
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 20, 2015 10:20 PM
popdedop
Sep 11, 2015 11:17 AM
