Jl Setup
Old Mar 23, 2008 | 05:51 PM
I VIK I's Avatar
Jl Setup
Hey guys, Needed your help on this one ( Audio noob), I finally saved up enough to pick up a JL system and Im planning to buy it myself becuase the local dealer is asking 2300 for everything installed. So far Im in the process of picking up a 13w7, a 1000/1v2 (is there any diffrence between this and the regular 1000/1) and the 13w7 prowedge w7 box. Now as far as installation goes and amp kits which would should I be getting what other things would I need. I plan to get this installed from a shop but I want to use as much jl equipment possible. so please let me know what size amp kit and what other things I will need.
Old Mar 23, 2008 | 07:59 PM
I VIK I's Avatar
Nobody can awnser?
Old Mar 24, 2008 | 04:18 AM
mendon99's Avatar
tastey wheat
why are you so sold on JL? Better is to be had for less money.
Old Mar 24, 2008 | 04:29 AM
spark plugs.'s Avatar
Hi, I drive a Maxima.
daught. and if you're serious about using JL for whatever reason, the same system can be had for less, too.
Old Mar 24, 2008 | 02:16 PM
I VIK I's Avatar
Ok So Ive got about 1500-1800ish? I was planning on a 1000/1v2 which goes for about 600 bucks or so and then the 13w7 in the prowedge box which goes for about 700 and then the wire ect so figure around there if you guys have suggestions Im open to them as you can see from my sig what I have now is really not sufficient so something that hits harder and clearer then the Jl for about the same price
Old Apr 20, 2008 | 07:25 PM
coyuma's Avatar
im working my way up to 13w7. so far i got the 1000/1 w/ a stinger 0awg wire kit to a stinger cap. the 1000/1 takes 4awg but i will run 2 amps off of the same power wire so i need the 0awg. that was $100-the 4awg costs about $60. now i got it wired to 2 12" audiofonics adf-292 rated at 1000wrms each w/ the amp turned very low and it bumps pertty hard
Old Apr 20, 2008 | 08:13 PM
01GLEMist's Avatar
If you're coming from a set of Sony's and want better, honestly thats not saying much. They are right. A LOT can be found for a lot less and it'll be better. Plus, if you blow that w7 a recone will run $300-400. Do your research. Build your own box to specs. Recommendations:
Amps:
Sundown
Audioque
Digital Designs
Hifonics, Crunch, Autotek (on a budget)
Subs:
Audioque
Alpine Type-R (on a budget)
Digital Designs
Fi Audio
Mach 5 (on a budget)
RE Audio
Here's the rundown. Get a Sundown 1500D for around 300ish. An Audioque HDC3 for $250ish and your wire (1/0 gauge) from Knukonceptz.com 3.25/foot. Build your own box ~50.
There you go, a better setup for about half of your budget. Spend some on a drycell battery and/or a new alternator.
Old Apr 20, 2008 | 08:19 PM
slickrick's Avatar
Crunch? Hell no...
Old Apr 20, 2008 | 08:32 PM
01GLEMist's Avatar
Originally Posted by slickrick
Crunch? Hell no...
It's the same thing as Autotek or Hifonics. Who do you think owns them? They're all owned by Maxxsonics
Old Apr 20, 2008 | 08:38 PM
AscendantMax's Avatar
RE and DD are uber expensive now. Don't forget about www.soundsplinter.com
Old Apr 20, 2008 | 08:51 PM
01GLEMist's Avatar
Yup, and if you get a DD, please write down your serial number.
I myself am deciding between 2 Type-R's in a ported box against 1 HDC3 in a folded horn.
Old Apr 20, 2008 | 09:05 PM
eh, just do the Rs in a good ported box. no way in hell you can cram a true folded horn into a trunk.
Old Apr 20, 2008 | 09:13 PM
01GLEMist's Avatar
I could if Pete K. designed it.
www.hexibase.com
Old Apr 20, 2008 | 09:41 PM
slickrick's Avatar
doesn't mean its the same. And neither of the other 2 aforementioned brands are great to begin with. I like the sub brand recommendations though.
Old Apr 20, 2008 | 10:06 PM
Pearl96Max's Avatar
I tend to get a bit irritable
So I suppose a Q45 is the same as a Sentra? All Nissan. Or maybe an NSX is an equivalent to a Civic? Eh all Honda must be the same..
Old Apr 20, 2008 | 10:07 PM
Pearl96Max's Avatar
Agreed.
Old Apr 21, 2008 | 06:35 PM
01GLEMist's Avatar
Hmmm....makes sense. I guess you guys are right. They wouldn't use the same quality parts....Now let me get back to driving my special edition FWD G35, i mean Maxima...ahem..lol
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 6, 2015 02:34 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
