New Plan of attack - questions
Old May 16, 2008 | 10:34 AM
Coolsaber57's Avatar
Hi guys,
Thanks for all the help with my subwoofer setup, I appreciate it.
I think I've decided on a new plan of attack for my audio system. I am going to get another amp to drive my front and rears, so I'm getting a 4 channel amp. I haven't decided on what I want just yet, but I'm gonna figure it out in the coming weeks.
My question comes to getting power and signal to both amps. I think that I figured out that you need a distribution block to get power to multiple item, but when it comes to signal, how do you do it? Is there a signal repeater/distribution block that you can use to split the signal to both the sub amp and the speaker amp?
Side question, what speaker size would I need to get for running to the doors and the rear speakers? I heard that 16gauge is good, but I just want to confirm.
Thanks!
Old May 16, 2008 | 10:57 AM
AscendantMax's Avatar
16 gauge is fine for speaker wire.
as for splitting the signal, some amps have an extra set of RCA input/out that lets the signal pass through and allows you to hook up another amp. or you can find y-spliters for pretty cheap online or at radio shack.
Old May 16, 2008 | 11:40 AM
So the y-splitters won't degrade the signal?
What about the remote wire then? Can I just tap that and route it into the second amp? Or is that not enough voltage?
Old May 19, 2008 | 12:07 PM
bump?
Old May 19, 2008 | 12:56 PM
ElVito1981's Avatar
Thanks!
Get the largest size possible, even if it takes extra work. I learned the hard way. I'm upgrading to 8" woofers cause the 6.5"s I have now just don't move enough air.
Old May 19, 2008 | 01:29 PM
Sorry, that was meant to say speaker wire size.
What about the remote wire? Can I tap the one running to my current amp?
Also, for the SLCs that I'm going to be putting in the fronts, I am looking at an amp that does 75w x 4, is that enough? Will it damage the speakers or anything like that? (my rears are alpine type-r coaxials)
Old May 19, 2008 | 05:33 PM
nope, you won't hear a difference. just make sure the splitter is of good quality.
the remote wire, you can t-tap it and route it to the 2nd amp. that's what i'm doing now on my setup.
Old May 20, 2008 | 08:22 AM
Awesome that's exactly what I needed to know.
Do you have any recommendations for a good distribution block that's not too expensive? I have a 4 guage power cable coming in, now if I have a 600w max amp and another amp that is about 375-450w, what size outlets would I need?
Old May 20, 2008 | 08:41 AM
whats the rms on the 600w max amp? something like 4 gauge in, 8 gauge out will work.
Old May 20, 2008 | 11:52 AM
Hmm, i believe it's 300w RMS (bridged). The instruction manual says "Rated Power Output" is 300w, so I'm guessing that means it's RMS.
Anything in particular I should keep an eye out for regarding the blocks? I've never run one before.
Old May 20, 2008 | 06:12 PM
nothing really. just make sure the connections on the distro block are secured and you'll be good to go.
Old May 20, 2008 | 08:44 PM
travmaximas1998's Avatar
for the remote just jump a wire from one amp remote to the other and ur done with that part
and al for distros look at these
http://knukonceptz.com/productMaster...0Fuse%20Blocks
and look at the KonFUSED distros
Old May 21, 2008 | 07:46 AM
Thanks for the help guys, I ordered my distro and some 8ga wire from ebay.
Should be picking up my new amp tomorrow for the speakers, and my SLCs should be shipping out on Thursday.
I can't friggin wait!!!
Oh crap, that means I have to go buy some 16ga wire. Bollux.
Old May 25, 2008 | 10:30 PM
you'll like those SLCs.
deaden those doors if you haven't already done so.
Old May 25, 2008 | 11:22 PM
What exactly does this "deadening" do?
Prevent rattling?
Old May 25, 2008 | 11:29 PM
yeah pretty much. it'll help with midbass response...and also helps reduce road noise from getting into the cabin.
Old May 26, 2008 | 02:15 PM
djfrestyl's Avatar
Suspension Yoda
Just to clarify because I didn't see this mentioned...
You need RCA splitters because you're still running the stock HU, right?
Old May 26, 2008 | 09:27 PM
No sir, JVC HU. It only has one set of RCA outs so, with 2 amps, I need to get 2 signals
Old May 27, 2008 | 05:00 AM
djfrestyl's Avatar
Suspension Yoda
Figured as much. G'luck with it.
Old May 27, 2008 | 08:03 AM
why thank you!
Unclejunebug
Apr 2, 2016 05:42 AM
newtomaxima
Sep 25, 2015 05:16 AM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
A32goldylocks
Sep 14, 2015 06:49 PM
