Plz confirm: Factory battery ground cable not needed after Big 3
Old Jun 11, 2008 | 06:32 AM
n3985's Avatar
大陆弟弟
My OEM battery is finally giving up, and has started to leak some acid between the caps (even burnt my new Racingline battery tie down!). I bought an Optima Red 75/35 and with the spacer on the bottom, my factory ground cable won't reach the new post.
But since I have the Big 3 done with Stinger 0 ga wiring, I technically should be fine since current flows through the path of least resistance correct? I am also using a Stinger battery terminal so for now the factory cable is taped up and put to the side. Thanks
Old Jun 11, 2008 | 11:48 AM
filtor1's Avatar
You will be fine.
smplyamzng
Dec 13, 2015 01:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
TonyJr
Aug 20, 2015 12:14 AM
Viralkill
Aug 16, 2015 05:09 PM
Superbform
Aug 11, 2015 08:10 PM
