These should go well with my dyns :)
Old Jul 25, 2008 | 05:10 AM
nismos14's Avatar
§è~® f®ÈÄk
They will be mounted IB
Makin the move to 10's IB.
Description Paramter Value Unit
Resonant frequency Fs 23 Hz
Half space sensitivity (1W@1m) SPL 81.7 dB SPL
Mechanical quality factor Qms 4.7
Electrical quality factor Qes 0.91
Total quality factor Qts 0.76
Equivalent Cas air load Vas 73 liters
Effective piston area Sd 333 cm2
DC Resistance Re 6.5 W
Voice-coil inductance @ 1kHz Le1k ? mH
Rated Impedance Z 8 W
Maximum linear excursion Xmax 19 ±mm
Maximum excursion before damage Xdam ? ±mm
Power handling capacity Pmax 300 W
Old Jul 25, 2008 | 06:42 AM
ElVito1981's Avatar
what is that? a sub?
Old Jul 25, 2008 | 06:58 AM
nismos14's Avatar
§è~® f®ÈÄk
lol.. yes.. a pair of'em in fact.
Old Jul 25, 2008 | 07:09 AM
ElVito1981's Avatar
oooh, what does IB stand for?
Old Jul 25, 2008 | 08:03 AM
burnurass's Avatar
you should PM don. he will know the answer
Old Jul 25, 2008 | 09:02 AM
meccanoble's Avatar
Sports Button FTW
with all the bass in the front, I can def see some accurate 10's completing the system. I'm also curious about this IB (in basement?) lol...
Old Jul 25, 2008 | 09:14 AM
ElVito1981's Avatar
honestly, I think 8's in the front is enough for bass...how do you have money for all this Parag--two cars, different setups all the time, haha.
Old Jul 25, 2008 | 11:48 AM
Pearl96Max's Avatar
I tend to get a bit irritable
IB = Infinite Baffle or sometimes called inaccurately 'freeair'.
Old Jul 25, 2008 | 12:01 PM
Pearl96Max's Avatar
Looks like a DPL10. Enjoy !
Old Jul 25, 2008 | 12:28 PM
meccanoble's Avatar
Sports Button FTW
Free air? I hope I dont sound too ignorant when I say this (everyone prepare yourself): I always thought of free air as a sub that does not require a box. For example, the 5th gens have an option for an 8" sub in the rear deck that just mounts back there without a box. Are you trying to do a similar setup with this? If so, how much custom work is needed to fit a 10" in the rear deck? What does the Altima SE-R come with stock back there?
What are the benefits of a free air sub vs a sub in a box? First thoughts say you can use your entire trunk as a box which would be bigger than any box you can fit in the trunk aka deeper bass...hopefully Im not getting ahead of myself here...
Old Jul 25, 2008 | 12:59 PM
Pearl96Max's Avatar
Not ignorant at all. It is a fair question.
Yes it uses the trunk as the 'enclosure'. It does require a bit of work, but payout can be great. Virtually no space taken and requires little power. However unless Very well planned out and implemented this would not work very well for the 'boomers'.
Old Jul 25, 2008 | 01:35 PM
meccanoble's Avatar
Sports Button FTW
No space taken is a huge plus and I can imagine the bass being much stronger with all that space used. But if you dont have a stock hole to begin with, sounds like a lot of work....nothing too difficult for Don *ahem*
Old Jul 25, 2008 | 02:07 PM
'96MaxGLE's Avatar
looks nice...what kind of sub is that? I probably just need to read the thread again, but i'm too lazy to scroll
Old Jul 25, 2008 | 02:13 PM
ElVito1981's Avatar
HAHAHAHA! Nice dude! Best post EVER!
Old Jul 25, 2008 | 02:14 PM
meccanoble's Avatar
Sports Button FTW
just checked the thread again (bored @ work), he did not mention the model...
witholding information nismo...selfish!
Old Jul 25, 2008 | 02:32 PM
Pearl96Max's Avatar
http://forums.maxima.org/6537744-post9.html
Old Jul 25, 2008 | 03:03 PM
AscendantMax's Avatar
so after looking forever for those old school pioneers you're not going to use them?
Old Jul 26, 2008 | 03:39 PM
nismos14's Avatar
§è~® f®ÈÄk
They are in right now lol They dont' sound bad, but with the 8's up front need more authority. These Exodus Audio DPL-10's should fit the bill pretty well.
Old Jul 26, 2008 | 03:43 PM
nismos14's Avatar
§è~® f®ÈÄk
We're all entited to our opinion.
Thats no concern of yours, (equipment goes through my hands quite often)
Yep, price was good, should be a good way to get my 10" IB feet wet.
I didn't have to do much custom work for 8's. Don and I did the first rendition with a little cutting, mdf rings and it was good to go. This will be similar but for the 10's I'll have to lose the torsion bars and use hood struts.
Old Jul 26, 2008 | 05:59 PM
meccanoble's Avatar
Sports Button FTW
Dont you mean trunk struts?
This looks and sounds like a hot idea. Hopefully on my next car, there is some type of opening back there for it.
I can see more authority being needed. I got an L7 in a ported box and still question where more bass comes from...up front or in the back...
Old Jul 26, 2008 | 07:06 PM
Pearl96Max's Avatar
No, he means what he said .. HOOD struts. That is what is needed to keep the trunk open.
Old Jul 26, 2008 | 08:36 PM
BLACKonBLACK98's Avatar
Former Vendor
actuators > hood struts
true story.
Old Jul 26, 2008 | 09:01 PM
Pearl96Max's Avatar
true story.
I concur. Well beyond his budget though. And ..I am Not installing them !
