Problem with backup camera and lights, Help me...
Old Sep 8, 2008 | 09:08 PM
kcxd35's Avatar
I provided a link to a video of my problem, Any thoughts will help and i tried putting a bigger fuse in a couple places (under the hood, fuse box) but it didn't help i didn't try putting a bigger fuse everywhere cause i don't know if it will burn out my circuit boards...Any insight will help save alot of time...
It only does it when i turn on the lights and that's parking lights or headlights...
http://myspacetv.com/index.cfm?fusea...deoid=42459544
Sorry i was trying to showcase some features for the 5th gen forum but that's the problem...
Old Sep 8, 2008 | 09:28 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Did you connect the proper illumination wire on the HU? Have you tried a video source and see if the problem is duplicated?
Old Sep 8, 2008 | 09:47 PM
kcxd35's Avatar
I connected all wires and it works fine it just gets grain interference when i put the lights on...
what video source???
Old Sep 8, 2008 | 09:50 PM
Pearl96Max's Avatar
Like perhaps a DVD? Are you sure you connected illumination and not the dimmer wire? What happens if you play with the dimmer control?
Old Sep 8, 2008 | 10:19 PM
kcxd35's Avatar
That's not the problem the dimmer and illumination both work fine, I think i have to use a relay and not connect the wires directly to the reverse wire....
tsi6001
Oct 3, 2022 10:23 PM
Maxilano
Aug 31, 2015 07:33 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
