The Ultimate Carputer - in an MR2
Old Sep 12, 2008 | 04:35 AM
djfrestyl's Avatar
Suspension Yoda
http://www.autoblog.com/2008/09/11/f...ate-car-puter/
Check out the gallery:
http://www.autoblog.com/photos/toyota-mr2-carputer/
Old Sep 12, 2008 | 06:59 AM
BLACKonBLACK98's Avatar
Former Vendor
wow. i've building a fairly ultimate carputer myself but i'm sooo putting in a larger monitor rotated vertical like that in place of the acc now.
Old Sep 14, 2008 | 09:47 AM
Yodastoe's Avatar
That is insane!!
Old Sep 14, 2008 | 10:00 AM
ICEMAN76's Avatar
That **** is HAWT!!!!!!!
Old Sep 14, 2008 | 10:47 AM
Originally Posted by Yodastoe
EDIT: That's insane!!
Anyway, yeah that is pretty impressive. Wish I had it in my car.
Old Sep 14, 2008 | 10:52 AM
djfrestyl's Avatar
Suspension Yoda
The installation doesn't seem that rough with the exception of the wiring and integration. What I'm really curious about is the programming.
Old Sep 14, 2008 | 11:15 AM
ICEMAN76's Avatar
So am I. Did they have to program the A/C unit controls, or are there already programs for that? More than likely pre-programmed huh.
Old Sep 14, 2008 | 11:20 AM
djfrestyl's Avatar
Suspension Yoda
Definitely need to wire up some sort of serial interface. Front-end display and controls is all programmed, then the back-end to interface wired to the car.
Either way, that's all I've got. The rest is over my head, unless there's some sort of interface kit.
Old Sep 14, 2008 | 11:23 AM
ICEMAN76's Avatar
True. Sounds like a beyatch to do. I wonder how many man hours that took? Removal, fabrication, installation, and functional checks, to make sure everything works. Looks like a PITA!! But excellent work!!
Old Sep 14, 2008 | 06:12 PM
meccanoble's Avatar
Sports Button FTW
yea i saw this on engadget.com earlier, sick. Odometer and everything changed up. I believe he asking for 10k for the car
Old Sep 14, 2008 | 06:31 PM
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
That is insanely awesome. Looks like something from star trek. Does all of that stuff work? It seems like interfacing with some of those systems such as climate control would be a royal PITA. First, you'd have to know what pretty much every wire running to the old climate buttons/***** did (not too hard if you've got the FSM or something). Then, you'd have to program the carputer to take input from the touchscreen (ie, "turn fan on") and send a signal (perhaps through the serial port) to a custom circuit that would set the appropriate voltages on the various climate control wires. That could get complicated quickly when you consider all the permutations (vent open, fan on; vent closed, fan on; vent open, fan off; vent closed, fan off, etc.) I don't know how he did it but off the top of my head, one idea would be to use an external microprocessor with a bunch of custom code to accept various commands over serial and output the appropriate voltages to the appropriate wires, with all kinds of fancy switching. This is a LOT of work for a one-man show.
anyway, very impressive! wish i had that kinda time on my hands.
Last edited by FunLovinMaxima; Sep 14, 2008 at 06:34 PM. Reason: engineering degree ftw!
Old Sep 15, 2008 | 11:52 AM
meccanoble's Avatar
Sports Button FTW
yea, i wish I could find the website posted, he gave a lot of pictures and details on what each screen does. Everything works and gives great detail on whatever you want to know about the car. He mentioned one thing not being hooked up though but it wasnt something big. Hopefully this is the wave of the future. Cars are now coming about standard with some type of screen, I can see technology slowly advancing, though, it also means more things that can go wrong and break.
Old Sep 15, 2008 | 12:04 PM
djfrestyl's Avatar
Suspension Yoda
More things can go wrong? You think? It's just changing from mechanical ***** to control boards, I'd imagine it would stay the same, just be more expensive.
Old Sep 15, 2008 | 09:43 PM
meccanoble's Avatar
Sports Button FTW
yea that is true.
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
