Fiberglassing help?
Old Sep 20, 2008 | 06:26 PM
JEXTEL's Avatar
Fiberglassing help?
I glassed my doors up and im having a slight door closin problem.. Like i have to really slam the door for it to close all the way..i think i may have to just sand it some more..
this is what i have so far.. Also do anyone have any tips? or a small cheap sander or some thing?
i still have to do my other door and dash so i can fit a 1 din, 2 din, and a 1/2 eq
Old Nov 19, 2008 | 02:09 PM
maxgen5's Avatar
This is an old post, but yes, just sand. I would suggest sanding more than you need off for tolerance and then re-apply some fiberglass resin and finish. The best way to hide imperfections after bondo is to do a vinyl overlay glued down with some 3M. If you heat it with a heat gun gently, it molds to fit almost any surface. Cut the vinyl to fit and spray both the panel and vinyl contact surfaces with adhesive, let it tack up and apply carefully. Once it is stuck, it is stuck.
Maxima_Joe
Nov 25, 2015 08:19 AM
Shadow
May 5, 2002 08:28 PM
ericdwong
Mar 31, 2002 08:31 AM
DaMaxima
Jan 16, 2002 11:38 AM
Zprime
Oct 26, 2000 06:47 AM
