Avic D3 Problem: speakers not playing
Hey guys,
I spend the last two days installing my avic d3 into my infiniti I30. Took forrver! we don't have any pink and blue VSS wires lol. Well i soldered everything together and connected it with the pac roem-nis2 harness.
It turns on, navigation works fine... but i have zero sound. I checked all the fuses they are working. I also used a voltmeter to check the speaker output on the HU and it does put out a signal, there is also a signal after the roem converter, although it is considerably weaker (that's what it is supposed to do right?) The amp also gets power, since i checked the voltage going into that. I have no idea what it could be, maybe except the amp blew all of a sudden.
Another thing. The harness had speaker hi and lo positives, the bose only has one positive line, so i soldered the hi and lo together and connected it to the harness. Could that be it?
thanks, i'll try, which one does the avic d3 use? high level or low level?
and now that you mention it i need to double check on the remote turn on.
what color is that wire?
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
