Shock sensor write up
Old Oct 23, 2008 | 10:40 AM
KiNgJaMEs's Avatar
Where can i find the write up for adding a shock sensor to my 5.5 gen?? need a write up asap please help
Old Oct 23, 2008 | 10:56 AM
KiNgJaMEs's Avatar
no one has done this??
Old Oct 23, 2008 | 01:50 PM
aznprid972's Avatar
There's a write up in the 4th gen stickies. Pretty much you tap Power/Ground and your signal wire that triggers it taps into your stock hood switch. The same switch that will set off your alarm if someone were to pop your hood when the alarm is set.
I'm looking at the 5th gen wiring, not 5.5, and it shows the hood switch is located at the Smart Entry Control Unit. It could be the same.
Old Oct 23, 2008 | 01:57 PM
KiNgJaMEs's Avatar
ill try it
thanks for the help.
my03maxima
Jul 28, 2024 07:40 AM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
