Pick Me a Headunit!
Old Nov 23, 2008 | 02:51 PM
Tatanko's Avatar
Bacon Lover
Pick Me a Headunit!
So I'm looking to pick up a headunit to replace the god awful stock one on my new Max. I'm not looking to spend a bunch of money, and I could probably pick one out myself, but I figure there are things you guys probably know that I don't and you can probably pick me out a better headunit for my money than I can.
What I want:
-Better AM/FM than the stocker
-Output for a sub/amp combo if I choose to add one later
-Ability to read burnt CD's
-Aux. input for mp3 player/iPod
-Preferably a **** rather than buttons for volume
-Some tuneability of settings
That's about it. I'm not hugely picky. I realize that just about any new headunit I look at will probably be able to accommodate most of those needs. Oh, and I'm looking to spend around $100, give or take.
Old Nov 23, 2008 | 03:07 PM
Tatanko's Avatar
Bacon Lover
I was thinking something like this:
http://www.crutchfield.com/p_130DEH2...P.html?tp=5684
I had a Pioneer as my last unit and loved it. Never had issues, worked great, and was simple to use. I have a question though...say I bought that headunit, wouldn't I need some sort of adapter to plug it into the factory wiring harness? Where would I find something like that and are there any plug-and-play available or going to have to make one that plugs in? Not a huge deal either way, I had to make a harness for my old one.
Also, for the record, I have a factory non-Bose stereo.
Old Nov 23, 2008 | 03:49 PM
travmaximas1998's Avatar
if you purchase a headunit from crutchfield, they will supply all the install hardware you need.
and if you walk over to sonicelectronix
they have very good prices and will also send some installation hardware.
i have personally purchased a headunit from them and it is working great.
here is the same pioneer headunit you are looking at just the new model
http://www.sonicelectronix.com/item_...H-P3000IB.html
Old Nov 23, 2008 | 04:09 PM
Tatanko's Avatar
Bacon Lover
I'd gladly pay $5 more for the newer model. Do you happen to know what all each of the companies supplies as far as installation? Like will both send the extra wiring harness (the one that you wire into the Pioneer harness that's included to make it plug-and-play into the factory Nissan harness)? What about DIN pockets and that sort of thing?
Old Nov 23, 2008 | 04:36 PM
BLACKonBLACK98's Avatar
Former Vendor
the main benefit of crutchfield is going to be the authorized warranty. they will also include everything needed for install.
it's my understanding that pioneer's quality has gone downhill as of late. they have been suffering issues even on their high end gear.
i think an eclipse cd1200 might be a good match for you. crutchfield shows it as discontinued but don (pearl96max) might be able to help you out.
*edit - found it at the crutchfield outlet:
http://www.crutchfield.com/p_099CD12...200.html?cc=02
Old Nov 23, 2008 | 07:31 PM
nismos14's Avatar
§è~® f®ÈÄk
Does this car have bose too? Then its the same exact install as the last, if not all you need is the metra 70-7550 harness.
Old Nov 24, 2008 | 05:47 AM
Former Vendor
reading > you
Old Nov 24, 2008 | 06:00 AM
nismos14's Avatar
§è~® f®ÈÄk
Never been a fan of reading.
Metra 70-7550
Old Nov 24, 2008 | 10:01 AM
Torgus's Avatar
+1 on the eclipse.
Old Nov 24, 2008 | 04:28 PM
Tatanko's Avatar
Bacon Lover
Went with the Pioneer DEH-4000UP. If I don't like it, I'll pawn it off on one of my friends who needs a headunit and get something else Got it from Crutchfield, so I got all the stuff free with it as well as free shipping. Ended up being $165, though.
Old Nov 24, 2008 | 10:22 PM
Pearl96Max's Avatar
I tend to get a bit irritable
No need to pawn it off, you bought it from Crutchfield, so you could always return it if you dont like it. Isnt buying authorized a nice thing?
Old Nov 25, 2008 | 02:42 PM
Tatanko's Avatar
Bacon Lover
Very good point. Also, it got here TODAY. I ordered it at 11:00 PM Sunday night and it was here at 9:00 this morning
Old Nov 25, 2008 | 04:46 PM
Tatanko's Avatar
Bacon Lover
Also...since it's been a while since I've done one of these...I just color-match right? Everything seems to line up pretty well with that and I double-checked it with the diagrams.
There are three wires I'm not using, though, and I'd like to make sure I don't need any of them. One I actually AM using, and would like to know if I need it or not, actually. They are as follows:
-A solid blue wire for the power antenna. There does not appear to be any corresponding wire coming from the headunit, and if I remember right, unless you're using the stock headunit you have to manually switch it on and off or it will be on (up) all the time. Am I right here? I'd prefer to just leave it down, as it doesn't seem to have a huge effect.
-A blue wire w/ white stripe for "amplifier turn-on." Again, there appears to be no corresponding wire coming from the headunit for this, and as far as I know there is no factory amp setup. Right?
-A black wire w/ white stripe for "amplifier shield ground." Instructions say to "connect to chassis of new receiver", so I added a connector to the end of this wire that I then screwed into the case of the headunit in a spot where an anti-theft thing was I think. Is this right? What is this for exactly?
-A blue wire w/ white stripe coming from the headunit labeled "system remote control terminal." What is this?
Old Nov 25, 2008 | 05:38 PM
Pearl96Max's Avatar
Blue/White from the HU needs to be connected to the Blue from the harness for your antenna to operate. If you dont wish to have AM/FM, then disregard. Blue/White and Black/White on the harness can also be disregarded since it is not used for Non Blose setups.
Old Nov 25, 2008 | 05:40 PM
nismos14's Avatar
§è~® f®ÈÄk
You use the remote turn on for the power antenna, but need to put a switch on it if you don't want it up all the time.
Read above
It is a ground and YES isntall it. Increase the wire length if you have to but ground that to the CHASSIS somewhere.
Uh you asked about this one already.
Old Nov 25, 2008 | 05:52 PM
Pearl96Max's Avatar
Read above
Reading > You.
1. He was already answered on all counts.
2. He is talking about the amplifier ground, not primary. REad: Black with White stripe.
3. First time he asked about Blue/White was in regards to the harness. The second was in regards to the HU. Not the same question.
Now, tell me you love me.
Old Nov 25, 2008 | 05:55 PM
nismos14's Avatar
§è~® f®ÈÄk
nismos14's Avatar
§è~® f®ÈÄk
btw, j00 check your paypal?
Old Nov 25, 2008 | 05:58 PM
Pearl96Max's Avatar
I did ! Spank ya.
Old Nov 25, 2008 | 06:00 PM
nismos14's Avatar
§è~® f®ÈÄk
Thank YOU sir, I'll call you after wrk tomorrow, may try to swing by.
Old Nov 25, 2008 | 08:00 PM
Tatanko's Avatar
Bacon Lover
I feel just as confused as before you answered me
I get that I need to ground the black w/ white stripe now, where would you suggest I ground it? I can't remember off hand any places to ground it to the car in that area. If I remember right the headunit I had before grounded itself through the DIN rack you sit it in, more specifically through the screws that hold the rack to the rest of the dashboard. Would these screws be acceptable to ground the two wires I need a ground for? That would be convenient for taking the DIN racks out later on so I didn't have to hold the thing while unbolting a wire some place else.
Do I or do I not need to hook up ANY of the other three wires?
Old Nov 25, 2008 | 09:05 PM
Torgus's Avatar
failz...
Old Nov 25, 2008 | 09:18 PM
Pearl96Max's Avatar
Im not sure where you are confused.
Also if you ever remove the HU, why would hold the bracket while unscrewing the ground? Just unplug the HU.
Old Nov 25, 2008 | 09:22 PM
Tatanko's Avatar
Bacon Lover
I COMPLETELY missed your post somehow
Fail on two counts I dunno wtf I was thinking when I made that post
I still have one last question though...why do I need to hook the solid blue from the harness to the blue/white from the HU to have AM/FM? Doesn't that blue wire just make the power antenna go up? Having it down doesn't stop me from getting reception; in fact the difference in reception is almost unnoticeable. I don't want to have to mess with a switch to make it not be up all the time, I'd rather just have it down all the time.
EDIT: Nismos answered my question over AIM.
Old Nov 26, 2008 | 03:00 PM
djfrestyl's Avatar
Suspension Yoda
No one caught this?
Not gonna happen. Because of the way the Nissan antennas are designed, and the way aftermarket HU's receive antenna input, your reception will surely diminish.
Old Nov 26, 2008 | 05:06 PM
shadyonedeath's Avatar
Alpine CDA series.
I have a 9847. it has everything you listed.
Old Nov 26, 2008 | 09:15 PM
Pearl96Max's Avatar
Originally Posted by shadyonedeath
Alpine CDA series.
Reading.
It has everything to do with responding to a post.
Old Nov 26, 2008 | 09:16 PM
nismos14's Avatar
§è~® f®ÈÄk
El oh el.
Old Nov 26, 2008 | 09:21 PM
Tatanko's Avatar
Bacon Lover
I got around to installing it tonight. Right away without even tweaking any settings, it was already worlds better than the stocker and even my old headunit. It distributes the different ranges much better than the stock headunit does, and the SuperTuner gives out much better AM/FM sound quality.
I need some sound deadening (just a little for the front doors, rear deck, and trunk lid), and a nice sub/amp combo for a wee bit extra thump. Whatever speakers this guy put in before I bought it aren't half bad. Nothing up the standards of the almighty audio section guys, but it's pretty good
Old Nov 26, 2008 | 09:31 PM
nismos14's Avatar
§è~® f®ÈÄk
Hit up Don - Pearl96Max for subs when ya ready
And when you can't afford his prices hit me up! LOL LOL :-D
Don, jew don't know how cheap he is, jew understand?
Old Nov 26, 2008 | 09:34 PM
Pearl96Max's Avatar
Ninja !!!
Old Nov 26, 2008 | 09:37 PM
nismos14's Avatar
§è~® f®ÈÄk
Lawl... check it again.
Pearl96Max's Avatar
This is acceptable.
Old Nov 26, 2008 | 09:59 PM
Tatanko's Avatar
Bacon Lover
I have a new question now: if I do add a sub later, there is a specific set of outputs for adding a sub (vs. 2 other sets for front and rear speakers). If I hook one up this way...does the headunit automatically know to sort of tone down the bass on the front/rear speakers and just direct it all to the sub? Or what? Because as it is I want to add the sub to get back some of the quality lost from the speakers having to do such a large variety of jobs range-wise (that and obviously they can't reproduce the same lows). I need some sound deadening big time too
Old Nov 26, 2008 | 10:02 PM
Pearl96Max's Avatar
Quite a few HUs nowadays do have a dedicated sub output.
Old Nov 26, 2008 | 10:04 PM
nismos14's Avatar
§è~® f®ÈÄk
You need to just bring the car to nj.
Old Nov 26, 2008 | 10:10 PM
djfrestyl's Avatar
Suspension Yoda
Agreed, makes life easier.
Pearl96Max's Avatar
I concur.
Old Nov 26, 2008 | 10:38 PM
Tatanko's Avatar
Bacon Lover
Jersey homos
I keed, I keed
Old Nov 26, 2008 | 10:42 PM
nismos14's Avatar
§è~® f®ÈÄk
BAN
