I Think My Subs Are Broken...
Old Feb 26, 2009 | 10:29 AM
shyheim07's Avatar
So I have two L5s given to me by a friend. Its starting to seem like sounds are missing out of the subs. Like it does not have a bass like it did when i first put them it. When i am outside of the car, u can hardly tell i have woofers and when i'm inside, its more of a bashing then bass, like they hit hard but it hurts..lol...i don't know. Does it sound like they are efed'up? I'm pushing them with a kicker 1000.1
Old Feb 26, 2009 | 11:20 AM
AscendantMax's Avatar
you're just getting used to it. and why would you want them loud OUTSIDE the car?
L5's are just plain sloppy imo.
Old Feb 26, 2009 | 01:33 PM
shyheim07's Avatar
i was affraid of that. yeah l5's are sloppy but they get the job done for the moment.
Ouside the car...well when i had l5s, Audioque HDs, Type R's and orions before..you can hear/ feel the base outside of the car...but i cant even tell subs are in the car at this point and it was kind of wierd to me...
Old Feb 26, 2009 | 01:44 PM
wait...you had an audioque HD and you went to L5s??
Old Feb 28, 2009 | 12:03 PM
shyheim07's Avatar
yea...i regret it forever, but the thing is I had 15" and they basiclly destroyed my trunk latch and removed my spoiler...plus it ws hell getting that box in and out. But after this BS, i'm gonna buy some 12" ones...
These L5s are just wack when it comes to sound...tey do hit tho..
Old Feb 28, 2009 | 03:54 PM
MadMaxSE-L's Avatar
Doggah Bite...
Ah, the Kicker db's...
Old Feb 28, 2009 | 08:12 PM
maximal01's Avatar
it could be a goof in the wiring somewhere, it happened to me when i put mine in also it wasnt abd just sounded weak an it turned out i had a positive and a neg backwards on both sides flipped it an it was a major change
Old Mar 3, 2009 | 07:38 AM
shyheim07's Avatar
Bingo....that was it... . Anther thing was the speakers in the rear deck were sort of cancelling the sound from the woofers out. So I took them out and hooked up the bullet tweeters in the rear door panels instead. Flawless...still want my HDs back though
Old Mar 3, 2009 | 12:03 PM
i wouldn't rag on kicker...some of the loudest setups i've heard are kickers.
Old Mar 4, 2009 | 05:28 PM
ridinwitha35's Avatar
Just give them more power...matter fact way more than the specs say.
Just playing....make sure your box doesn't have air leaks (ported or sealed?), double check your LPF (and HPF if you're running a ported setup), double check the polarity if you have more than 1 sub to make sure you're not running 'em out-of-phase, try measuring the VC's resistance with an Ohmmeter, should be close to the nominal impedance (but won't be exactly since it's just a DC measurement), also sometimes placement of the subs can have a big impact on the output...think about nulling or reinforcement (of sound waves).
But the other guy was right...you probably are just geting used to it...(e.g., losing your hearing).
Redfox
Sep 28, 2015 10:41 AM
Taino14
Sep 24, 2015 02:51 PM
ballerchris510
Sep 23, 2015 08:46 PM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
