Removed alarm horn = no start
Old Mar 16, 2009 | 02:46 PM
Gunther's Avatar
How do aftermarket alarms typically go about keeping a car from starting? I removed the alarm horn and the alarm won't stop triggering. I'd prefer to completely remove the alarm than to put the horn back in.
Old Mar 16, 2009 | 05:41 PM
burhan92SE's Avatar
they r connected to ur ignition directly and prevent the current going to the starter motor from ignition switch...but may vary with different alarm systems....u don need to take the alarm horn jus put the key in ur D -Side door and close it. open it again and alarm will shut off.....r u talkin about factory alarm system on max? cuz i m...
Old Mar 16, 2009 | 05:56 PM
Gunther's Avatar
aftermarket - stock uses your regular horn doesn't it?
Old Mar 16, 2009 | 09:15 PM
Gunther's Avatar
Do alarms work passively or actively? If I cut out the brain of it will my car still not start?
Does an alarm have an always on signal saying its okay to start, and if its absent it wont start? Or does it do nothing until its activated?
Old Mar 17, 2009 | 09:59 AM
Gunther's Avatar
I got the car starting so nevermind
Old Mar 17, 2009 | 11:08 AM
mendon99's Avatar
tastey wheat
the starter kill was probably engaged, and for whatever reason its now reset. When alarms are installed properly, the starter wire is opened with a relay. If you want, go into the underdash find the starter wire and cut it away from the alarm, reconnect it.
Old Mar 17, 2009 | 02:02 PM
Gunther's Avatar
Yea, that's what I did. I just removed the alarm completely.
Old Mar 17, 2009 | 09:38 PM
burhan92SE's Avatar
gud now u know how to do it....
Hdnseek
Sep 9, 2015 05:55 AM
Colossus
Sep 9, 2015 05:46 AM
lowpost99
Sep 8, 2015 05:06 AM
trungg86
Sep 4, 2015 04:58 AM
