2006 infiniti G35 Coupe alarm install issues..
Old Mar 18, 2009 | 04:49 PM
DcMaN's Avatar
I know this isnt a maxima, but i know that there are alot of people on the org that install alarms/remote startsso im hoping that some one will see this, and shed some light on my situation.
Im having trouble locating the BCM for my car, If you read this link apparently some cars have different BCMS. Reference Post 1 (this is the CORRECT BCM), and if you reference post number 15(that is how my bcm looks, and all the wire colors are either incorrect or missing according to the latest directechs. I am having trouble finding the door trigger / and the trunk hatch pin. Please can some one help me i have those two wires left and i would like to close up the underneath of my dash.
Thanks in advance
http://www.g35driver.com/forums/audi...sor-cabin.html
Old Mar 19, 2009 | 04:50 AM
mendon99's Avatar
tastey wheat
So you have a coupe and the BCM is NOT located in the drivers kick?
Edit: ok I understand now. You sure you're looking in the right plug? are you grabbing dome sup or door trigger (for door trigger)?
Old Mar 19, 2009 | 07:11 AM
DcMaN's Avatar
I know where the bcm is, its just that I am having trouble finding the correct wires if you look at the directechs wiring it says that the driver door trigger is in pin 62 ( I don't have a pin 62) unless the count all 3 connectors at the bcm as one giant continuous plug. I have two wires left that I can't find, passenger door trigger, and the trunk / hatch pin. Any help is appreciated
Old Mar 19, 2009 | 07:32 AM
mendon99's Avatar
tastey wheat
you could always go straight to the respective pins. More work, but it'll be done. DEI might be able to shine some light on it, if you have a shop name/number..
Its odd that you cant find them though, i feel like you're testing improperly or something... do you keep the ignition on when testing for door trigger/dome sup? its easier
Leave the dome light on and start unpluging the plugs one by one, that would point to your dome sup if you'd rather use that..
Old Mar 19, 2009 | 08:23 AM
DcMaN's Avatar
All 3 connectors when unplugged shuts the dome supervision off WTF. I'm about to just go to the passenger side and run a wire from the door trigger over to the alarm brain, samething for the trunk pin. Because this is getting ridiculous that there are no pinouts for the BCM that i have.
Old Mar 19, 2009 | 08:50 AM
mendon99's Avatar
tastey wheat
all 3 at once? or individually? I can't imagine that the pins arent there. Make sure you don't have an ECM or ECU, then run the wires manually. Im gonna check one more place for BCM location...
Old Mar 19, 2009 | 08:54 AM
mendon99's Avatar
tastey wheat
Ok Xpresskit says the location on the BCM is the driver kick, im now convinced you have the right brain. Yeah I would just run the wire manually, what else can you do if you've checked all the wires. Make sure your test light/DMM is working properly (yeah, ive seen it before, lol)
Old Mar 19, 2009 | 05:05 PM
DcMaN's Avatar
haha yea it works, im just gonna run the wires from the respective door trigger. Whats the easiest way to est for the trunk or hatch pin
Old Mar 19, 2009 | 05:13 PM
mendon99's Avatar
tastey wheat
good chance that its the same color as the trunk pin BCM wire. get in the trunk from the cabin test the all the wires while closed, open the trunk look for the one that changed i guess.
9aj9
Apr 5, 2020 12:11 AM
pktaske
May 6, 2016 07:49 AM
DrVee
Sep 4, 2015 12:18 PM
pktaske
Sep 4, 2015 08:40 AM
