How to properly ground a Maxima alternator ?
Old Apr 18, 2009 | 02:00 PM
gallilaw's Avatar
I am re-wiring a 1998 Maxima. The FSM shows that a ground wire attaches to the alternator at Teminal E. The Nissan dealer recently installed a re-manufactured Nissan alternator.
When I took a look at the alternator at home, I could not find a ground wire connected to it -- and frankly I could not see a Terminal E either. I looked at the alternator from the top and from the bottom. If there is a Terminal E I surely missed it.
I was going to post a photo showing the wire bundle, but I notice that I am not allowed to put up attachments.
Anyway, the same wire bundle that contains the booted connector to the positive terminal also contains a short black wire with a ring terminal -- that was grounded to a metal fitting that was attached to some body metal, NOT directly to the alternator or to "Teminal E."
I am assuming without knowing for sure that this short black wire is the ground wire that the FSM thinks will be attached to Terminal E -- if it exists.
Can someone please help me by confirming how to ground the alternator in accordance with the FSM -- and in doing so confirm whether the black wire shown bundled with the booted connector is the proper ground wire -- and where it in fact should be attached.
Thanks.
Old Apr 20, 2009 | 08:17 AM
djfrestyl's Avatar
Suspension Yoda
I wouldn't worry too much about it, the alternator only really has two connections - the positive wire and the harness for the voltage regular - both of which are very obvious.
Old Apr 21, 2009 | 01:01 AM
The Godfather's Avatar
Isnt the alternator already grounded to the engine? to which the battery is connected to? ....
Old Apr 21, 2009 | 06:14 AM
djfrestyl's Avatar
Suspension Yoda
Yes.
Old Apr 22, 2009 | 10:13 AM
Batxel's Avatar
blah
There is ground wire for the alt as shown below. Bolting it up to the car should be sufficient though.
PH98I30
19
Jun 13, 2016 02:38 PM
Balkins
Feb 1, 2016 12:45 AM
kenc15
Sep 25, 2015 06:38 AM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
