Problem with door light, please help
Old Nov 21, 2001 | 08:43 PM
maximaracer28's Avatar
Ok I bought cefiro indiglo kickplates, and decided to wire them to my door lights. Now, my pass side is all done and looks great but my driv side door light does not work. First off I took the door light out, and stripped the 2 wires for the door light, then ran 20 gauge wires to the kickplates. Now, I made the mistake of cutting both wires at the same time with snips, and then the light went off. Now my pass side door light works but drivers side doesnt. I was told by the dealer that I was missing a ground? I am not sure what that means, and I dont think there are 2 seperate fuses for each door? If anyone can please help it would greatly be appreciated. Thanks,
Mike
Old Nov 22, 2001 | 08:42 AM
mb1's Avatar
mb1
Did you check if your lightbulb burnt out? Also theck whether there's any voltage with a volt-meter
Old Nov 22, 2001 | 09:35 AM
yes I checked if the bulb was burnt out, and I dont think there is any power going to it...
Old Nov 22, 2001 | 03:09 PM
mb1's Avatar
mb1
How did you run the wire into the door? Did you go through the factory wire bundle?
Old Nov 22, 2001 | 04:31 PM
no, i took the door light out...then stripped the 2 wires that power it...then simply ran 2 20 gauge wires to my door sill...and bingo..but liek is aid i cut the 2 wires by mistake at the same time not thinking...and it went out...and im afraid its either somethign withthe wiring but was told it jsut doesnt have a ground, and im not sure how to proceed with this...
Old Nov 22, 2001 | 06:22 PM
mb1's Avatar
mb1
Ok I'm confused. You are talking about the lights that are located on your door pannel? What do you mean by door sill? You tried to splice the kicks to the door light, right? When you cut them both you could have posibly shorted the connection with the cutters, wich could have blown something. Can you return everything to the way it was when it was working? Sorry if I'm not much help, but I'm just trying to visualise your problem.
Old Nov 24, 2001 | 06:48 PM
Ok here is a diagram, sorry about the sh!tty quality...hope it helps ..have an e-mail where i can send it to? fiel is too big to fit ont he org
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
homeyclaus
Sep 3, 2015 06:15 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Samedi
Aug 13, 2015 04:05 PM
