speaker mounting..?
Old Nov 23, 2001 | 01:13 PM
Speebs's Avatar
I aim to misbehave.
speaker mounting..?
Hey guys... I have 4 entry-level blaupunkt speakers that I'd like to use to replace the stock speakers in my 95 GXE. My problem is that the mounting screw holes are not in the same places as the stock speakers'. Are there adaptor brackets for this purpose, and if so where can I get them? If not, what can I do to make the speakers screw into the door? The model number of the new speakers are P652C.
Thanks in advance....
Doug
Old Nov 23, 2001 | 03:01 PM
Whitemax's Avatar
Disco Biscuit
Well, since the new speakers are 6.5" and the stock are 6.75" you need to make an adapter. If you have a jig saw then cut a ring that fits the factory mount, and then a hole in the middle that fits your new speakers.
Old Nov 23, 2001 | 06:50 PM
Speebs's Avatar
I aim to misbehave.
Cutting a ring is a problem... There's no way I will be able to cut a circle for the speaker to fit into. The holes for the screws will just be way too close to the inside edge of the ring and will probably split if I try to screw it in. How come nobody else seems to have this problem?
Old Nov 23, 2001 | 07:02 PM
ny96max's Avatar
stock are called Over sized speakers.... i sugest making a small adapter out of 1/4" plywood using a dremel or jigsaw. Shouldnt take that long to make. Or you can have them made up at a locla car stereo shop for around $20-40 depending.
Old Nov 23, 2001 | 07:47 PM
jmax
Cut it out of MDF. It shouldn't split. And you'll end up with a better seal to the door than factory.
Old Nov 23, 2001 | 07:55 PM
seven's Avatar
easier solution:
use the plastic bracket that is already on your stock speakers. use a flathead to separate the plastic part from the metal part. this will be your adapter. now put your aftermarket speaker on the template, mark the holes and drill into the plastic piece. screw the speaker to the plastic piece and then screw the entire thing back into the stocl location.
Old Nov 23, 2001 | 08:19 PM
Speebs's Avatar
I aim to misbehave.
MDF? It doesn't really matter anyway.. I don't have access to the resources necessary for cutting circles. Oh well. I will try using the backs of the old speakers.
Old Nov 23, 2001 | 08:29 PM
jmax
If you have 5 friends and half of them have fathers then you probably have at least two places to draw the resourses.
Old Nov 23, 2001 | 09:43 PM
Speebs's Avatar
I aim to misbehave.
Trust me, I do not have the resources. If I had friends, I wouldn't be on this message board so much.
Old Nov 24, 2001 | 06:39 PM
djslinkyz's Avatar
autotoys.com has one, i think its like $17
Old Nov 24, 2001 | 08:06 PM
jmax
Hot damn! Only $17.95 for a brand spankin' new friend?
Old Nov 24, 2001 | 11:40 PM
Speebs's Avatar
I aim to misbehave.
To which one are you referring? The one that adapts 6.5" speakers to an 'OEM 6.75" opening'?
Old Nov 25, 2001 | 11:01 AM
emax02's Avatar
Old Nov 25, 2001 | 11:05 AM
Quack 2x's Avatar
Originally posted by emax95
Hope it's going to be a *really* good friend if you're going to be spanking him...
Quack2x
Old Nov 25, 2001 | 01:53 PM
djslinkyz's Avatar
yeh, that's the one. i'm not sure if that's the right price though, i just pulled that number off the top of my head.
Old Nov 26, 2001 | 06:30 AM
jmax
Quack2x
Uhhhhhhhhm? Don't you mean her? Spanking her?
Old Nov 26, 2001 | 06:33 AM
jmax
And I hope she comes equiped with all the needed hardware. I mean install hardware like a jig saw, roto-zip, belt sander, fiberglass spreaders, damping mat rollers. And anything "else" that may come in handy.
Mar 12, 2020 12:06 AM
magiconthetire
Oct 26, 2015 09:03 PM
Excalibur23
Oct 13, 2015 04:33 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
