Rear door (driver side) is locked from inside and outside .. please help
Old Nov 4, 2009 | 12:23 PM
amansour14's Avatar
I have Nissan Maxima 2002 SE
My rear driver side door is locked and I can not open the door from inside and outside ... I can not open it from inside because the child lock is on but I do not know why I can not open it from outside ... Maybe the exterior door handle is bad ...
the center lock is working fine..
I do not know how to remove the inside door panel .. because it is locked
Is there a way to remove the exterior door handle without removing the interior door panel?
please help ... anyone has the same problem before ?
Old Nov 4, 2009 | 02:01 PM
JNCoRacer's Avatar
Just the tip.
Had this happen before. Take the door handle trim off. Remove the 10mm bolt holding the handle to the door. Then with a pair of needle nose pliers grab the locking "rod" and pull it towards the front of the car.
That should unlock it.
Once the door is open take the panel off so you can remove the inner door handle. Theres a hole where the hooked end of the door lock "rod" goes in. They have the tendency to break over time. No good way to fix it, but replace it with one from like a junkyard.
Old Nov 4, 2009 | 02:51 PM
amansour14's Avatar
How to take the door handle trim off? and Did you mean the inner door handle trim or the exterior one? I understood the exterior one ..
I tried to took it off before but I could not .. can you please tell me how to take it off?
Old Nov 9, 2009 | 11:17 AM
djfrestyl's Avatar
Suspension Yoda
Interior door handle trim. The 'ring' around the handle.
Use a small flathead screwdriver. Be very careful.
Option #2: remove your lower rear seat and try to remove the interior door panel from there.
rtirbany
Sep 8, 2015 11:46 AM
Stelianos
Aug 19, 2015 02:07 PM
shaunkey1
Aug 18, 2015 10:09 PM
