Arc Audio 2500-XXK vs. Blown Internal Fuses
Old Jan 16, 2010 | 08:56 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
What's up, guys? I hope all is well. I'm hoping you can help me troubleshoot a little problem I am having here...
I have an Arc Audio 2500-XXK that has sat dormant for about 2 years in my garage and I have finally gotten around to installing the beast. So I connected everything up as normal only to discover she's not firing up. After troubleshooting the obvious turn-on/ground/power lines, I opened up the chassis to discover that all 3 30-amp fuses had blown. Hoping this to be a one time event, I purchased a new set of fuses and again then went.
Any ideas as to what I can do to troubleshoot the matter, or does this need to be sent out for repair?
Old Jan 16, 2010 | 11:50 AM
mendon99's Avatar
tastey wheat
unfortunately, it probably needs to go out for repair. I want to say I've heard of these amps with this problem before... I could be wrong though.
Old Jan 16, 2010 | 12:30 PM
AscendantMax's Avatar
yeah, sounds like it needs some repair work.
kinda silly but i've accidentally connected the power and ground backwards on my 1500-xxk and blew all the internal fuses. maybe you had a brainfart and did the same?
also make sure there are no frayed wires from the power wire touching the ground terminal.
Old Jan 16, 2010 | 03:29 PM
I wish. I sourced out all of the stupid obvious things...no dice.
Old Jan 16, 2010 | 10:34 PM
call up Mister Amann and see if he can do anything to help you out.
Old Jan 17, 2010 | 11:08 AM
nismos14's Avatar
§è~® f®ÈÄk
Dunno if Don still deals the Arc jokers.
Old Jan 17, 2010 | 12:19 PM
Who's that?
I am missing something here. Arc and Don were like two peas in a pod last I was working on Audio...what happened?
Old Jan 18, 2010 | 07:10 PM
$150 flat-rate, regardless of issue.
Not bad.
Old Jan 20, 2010 | 10:45 AM
Originally Posted by Metal Maxima
Who's that?
Don's last name.
Arc and Don...well they have a different relationship now...
Old Jun 13, 2010 | 12:26 AM
S1cTech's Avatar
ARe you selling that ARC Audio 2500-XXK? Did you find the issue with it? Ill take it. If its working fine.
Old Jun 15, 2010 | 12:13 PM
Stalldaworld's Avatar
hell i will buy it broken and send it out to get it fixed....lets talk price if your interested in selling. i need a match for my 4 chan
James92SE
142
Jan 2, 2024 09:23 AM
Fbana41
Aug 29, 2016 12:18 PM
leatherneck
Sep 30, 2015 09:16 PM
Maxie40
Sep 14, 2015 11:28 AM
