resistor wattage??
Old Dec 8, 2001 | 06:40 PM
multiplexor's Avatar
resistor wattage??
Hey, quick question.
I need to use a 470 ohm resistor to down 12 volts to 3 volts.
my question is:
What size resistor should i be using?
1/2watt? 2 watt?
should i be looking into wirewound resistors?
i have small half watt resistors right here, but i think they
might blow up or something.
any help would be great... anything!
thanx a bunch
Old Dec 8, 2001 | 08:12 PM
jiaxima96's Avatar
Re: resistor wattage??
my question is:
1/2watt? 2 watt?
So the voltage drop on 470 ohm is 9V. The power dissipation on 470 ohm will be (9V*9V)/470, which is about 0.17 watt. So a 1/2 watt resistor would be OK.
Wirewound resistor is generally of high power rating if I remember right.
Old Dec 10, 2001 | 07:18 AM
Re: Re: resistor wattage??
<ME>
Sits in class, watching
jiaxima96 teach. Learns much from lesson.
</ME>
So the formula for power dissipation and to generally tell what voltage type resistor to use is (Voltage to lose * Voltage to lose)/ resistor ohm-age.
hmm cool. i was worried for like 3 hours before i decided to try plugging it all together...
i'm attempting 3 capacitors of 10,000 uf's each, hooked up to my front dome lights... the ones for the passenger and driver. 12 volts will go into those... or 3... however i decide to hook it up. and the goto, i dunno yet, maybe 4 leds per side (driver/pass).
so far it works nice in my house.... just gotta get it all functionning in the car now.
I was lucky to find a 12 volt output transformer in my place
anywho, Thanks a bunch
knight_yyz
Nov 1, 2015 01:34 PM
Turbonut
46
Oct 21, 2015 08:28 PM
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 23, 2015 08:46 PM
