2 12's or 1 15???
Old Dec 12, 2001 | 04:28 PM
puremax's Avatar
2 12's or 1 15???
Umm yes yes hello there. I'm going to be getting my full system installed soon. but i am so stumped. Should i get 2 12 inch Kicker L7's or 1 15 inch L7? I can't decide. please give me all opinions. If you were in my shoes what would u get? has anyone ran into this problem? thanks for your concern.
the*juice
Old Dec 12, 2001 | 07:29 PM
MaxedOut2g's Avatar
Re: 2 12's or 1 15???
the*juice
i would go w/ 2-15"... , haha..but to answer your question
2-12"...juss cuz it looks better, to me atleast, to have 2 subs rather than 1...i have 2 12" L7's and i love em....
atw
Old Dec 12, 2001 | 08:27 PM
jmax
Normally two twelves have a slightly larger total surface area than a single fifteen. So that's the route I would go. But there are other considerations such as the required box volume for two twelves as opposed to the volume needed for a single fifteen. And how you plan to amplify the subs.
Old Dec 13, 2001 | 12:15 AM
puremax's Avatar
I am using an Autotek Stealth series amp. the wattage is 1200x.
Old Dec 13, 2001 | 03:55 AM
deezo's Avatar
I have one 12 and the system kicks.
Old Dec 13, 2001 | 12:30 PM
DARTHSWAN's Avatar
the*juice
I have to agree 2 15's is the way to go. I have 2 and I'm planning on getting 1 13w7.
K
Old Dec 13, 2001 | 10:06 PM
jmax
Is this a stereo or mono amp? And what is the lowest recommended impedance? The L7's have either dual 2 ohm coils or dual 4 ohm coils. If you are getting two speakers then that will be 4 total coils to hook up to the amp.
Old Dec 15, 2001 | 01:37 PM
puremax's Avatar
What do you mean by stereo or mono amp? does that mean 1 channel or 2 channel? can't compute.
Old Dec 15, 2001 | 04:39 PM
jmax
Stereo would be two seperate channels, most often bridgeable. Mono is monaural. One channel.
Old Dec 15, 2001 | 08:33 PM
puremax's Avatar
The amp is 2 channel, think it will be to weak to push those L7s?
Old Dec 16, 2001 | 05:51 AM
jmax
When the amp is bridged, to what load is it stable? Match the speaker impedance to the amp. If you are getting two or more speakers, and I think these speakers are dual voice coil, make sure you calculate the impedance that the amp will "see".
Old Dec 16, 2001 | 11:56 PM
puremax's Avatar
ok i know i said it wasn't mono. sorry but i lost the model number of the amp i was getting but i am pretty sure this is it.XS-1500.1
Class-D Mono Block with Dual 2 Awg. Power and Ground Terminals
450 WATTS X 1 CHANNEL @ 4 OHMS
900 WATTS X 1 CHANNEL @ 2 OHMS
1500 WATTS X 1 CHANNEL @ 1 OHM
XS-1500.1
just thought u might like to read this.
The Stealth concept was created after careful observation and listening to the most beautiful and musical amplifiers at the World Finals. The need for an amplifier which could be flush mounted without elaborate baffles and cover panels was obvious. Stealth fills this need, and is designed to reduce custom installation time by 80%. In addition, we designed Stealth to perform flawlessly into 1-ohm loads, with the musical ability of amplifiers three times it's cost. Stealth Series high performance amplifiers feature our patent pending flush-mount heat sink and chassis for invisible wiring, 1 ohm stability, variable low and high pass crossovers, variable 0-18dB bass boost, line outputs, on/off subsonic filter, all mosfet design and full protection.
check out the w\s.
http://nexxon.com/autotek/autotek_stealth_amps.htm
Old Dec 17, 2001 | 12:02 AM
black019's Avatar
XS-1500.1
check out the w\s.
why dont u write a book about it
tha ice!
Old Dec 17, 2001 | 12:38 AM
chinaonnitrous1's Avatar
geeeeeez......im hoping your gonna be going for some SPL.....cuz damn the last time i heard a set of 15" woofers...it was a lil while back..listening to Ice Cube's hit..."its a good day"...( its a good day..didn't even hafta use my AK)...rolling in a ghetto 5.0 mustang..with some budget beat 15" woofers wiht some puny 50 oz magnets..and a flea market amp.. Im sure the kickers are awesome...but 15" is alot of cone to move for a speaker..i hope your not gonna try to play music with over 110 beats per minit...cuz i know damn well that 15" just can't keep up with fast beats..id go for the 12"s for a good balance of SPL and sound q
Old Dec 17, 2001 | 08:46 PM
jmax
I would go for 2 subs with dual 4 ohm coils. 4/4 = 1 ohm. That will give the most output. Otherwise 2 single voice coil subs, 2 ohms each. 2/2 = 1ohm.
