speaker help
Old Dec 15, 2001 | 10:46 PM
hockeyghst's Avatar
speaker help
ok its 12 43 am and i just got home from hoceky so i figured it would be a good time to put my cd player back into my car and everything is good until i turned on the radio....i couldnt hear anyhting from the speakers....i checked the wires in the back they are all taped up and i dont see any loose connections....i checked all my audio fuses and they seem to be ok........i dont know what going on this electricla problem was ****ing me off for a while i finally get it fixed and now i cant hear anything from my speakers so i do not know where to begin......maybe i hooked up the wires wrong from the cd player to the wiring harness??? i put the yellow memory wire to yellow off the harness then i put red and red together for power.....one red is accesories the other red was 12 volt power........and i connected the 3 blue remote wires........all the speaker wires are wired correctly.......i dont know what swrong can anyone help???
95 max pioneer head unit
Old Dec 15, 2001 | 10:53 PM
emax02's Avatar
Re: speaker help
Does your headunit turn on? If so either your Power wire{not remote power wire} is not connected{or fuse blown} or maybe your ground wire is not hooked up right. Double check those 2 wires and all your fuses{including the factory fuse box fuses}. Another very slim possibility is you hooked something up wrong before and blew your head unit, I would think it's protected by fuses though.
Old Dec 16, 2001 | 04:00 AM
THAWABUTT's Avatar
Same thing happend to me back in the day. If you connected power before speakers you most likely blew a fuse, like emax said. Check the factory radio first then the fuse in the back of the radio then check the rest of your fuses. Otherwise I don't know what the problem is.
Old Dec 16, 2001 | 10:30 AM
hockeyghst's Avatar
Re: Re: speaker help
ok well i probably should have mentioned this before......my cd player turns on i hear the beep noise when i scroll through the options on the cd player....i set a station and i tunred my car off and back on and the pre set stayed so i knwo the memory wire is hooked up right......i checked the bose fuse and it is fine i dont knwo what is causing this not to work.,....i have taken my wire harness out of my car and wired it plenty of times to know what wires hook up to what so i know i wired it right....but then again it was kinda late and i was only on 4 hrs of sleep so maybe i wanst thinking to good.....the only thing i can think of is that i have a wire either not hooked up or not wired to the correct wire but i dont know how this is poeebily if i have done it so many times before and i have gotten it right every single time.......as soon as i get some time i guess ill have to pull the cd player out again and double check my wires......I donno this is ****ing me off
Old Dec 16, 2001 | 10:32 AM
hockeyghst's Avatar
if i did blow a fuse which fuse would it be do u know????
Old Dec 17, 2001 | 04:02 PM
ny96max's Avatar
grab a test light and start testing every fuse in the panel. Sometimes you can blow a fuse that you would think had nothing to do with your problem.
Old Dec 18, 2001 | 10:21 AM
hockeyghst's Avatar
yes every fuse works....still no problem solved
Mar 12, 2020 12:06 AM
magiconthetire
Oct 26, 2015 09:03 PM
Excalibur23
Oct 13, 2015 04:33 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
