Confirming a few things
Old Dec 16, 2010 | 10:07 PM
02SEMax's Avatar
I'm wanting to get a new stereo, I was looking at the Pioneer 4200UB
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
I wanted to make sure that would work with the metra 70-7551 and see if anyone had experience with it.
I also wanted to confirm a few installation things:
1. That the 70-7551 would work with the stock BOSE stuff (I know the BOSE stuff sucks, but I can't afford to replace the speakers and everything)
2. That to get the TRIP button to work I just needed to ground the brown wire in the smaller clip of the stock stereo (I know that this will not make the steering controls work)
Also, has anyone had experience with this schosche installation kit? Like quality, color match, etc.
Thanks for any help!
Old Dec 16, 2010 | 11:47 PM
Shady680's Avatar
I have the same schosche kit installed in my car with a double din nav unit. Overall I think it is good, the color match is close but under bright conditions you can clearly see the difference. Also the unit is not as sturdy as the stock mount because it is all plastic. The nav unit I have is quite heavy and the schosche supports flexed a bit when I installed it. It does the job and looks good and for the price I think it is worth it.
Here is a pic I posted a while ago. It's kind of dark but you can still see the color is off a little bit.
Old Dec 17, 2010 | 05:39 AM
djfrestyl's Avatar
Suspension Yoda
Confirmed for both 1 and 2.
As for dash kit, The Scosche is decent and does the job. If you use all the needed brackets it's firm enough, and you'll NEVER get 100% color match unless you get a GXE kit, which can set you back $100+.
Old Dec 17, 2010 | 08:02 AM
eatfly's Avatar
One thing to keep in mind is the width of the unit. I have a Pioneer MVH-8200BT and it wouldn't fit the Scosche dash kit because the Pioneer was too wide.
I ended up having to get the Metra 99-7416. The fit is okay, not perfect. However the plastic on the Metra is completely black. I just eventually got used to the color mismatch.
Old Dec 17, 2010 | 08:40 AM
Froggmann's Avatar
Just went though this myself and yes the 70-7551 will work to install an aftermarket HU. Just make sure you connect the amp wire. For some reason I forgot that last night and it took me an extra 15 minutes to figure out what the heck I did wrong.
I still have no idea what the heck I'm doing wrong but the trip button still doesn't work for me. Brown wire is grounded. just nothing happens when I press the trip button.
The Scorsche kit works fine. Yes the mounts feel a bit flimsy but if you support it while screwing in the top[ screws it holds quite well. Yes there is a slight color mismatch on the surround but it's mostly the texture that you will notice versus the color:
This was taken this morning:
Old Dec 17, 2010 | 08:23 PM
02SEMax's Avatar
Thanks for the input everyone, i really appreciate it. I just ordered the stuff and got a hella good deal. Gonna get it next week.... i can finally get rid of the ****ty *** clarion stock unit
Old Dec 17, 2010 | 10:51 PM
djfrestyl's Avatar
Suspension Yoda
Good luck!
Where are you located?
Old Dec 19, 2010 | 08:08 PM
02SEMax's Avatar
Good luck!
Southern Illinois, near St. Louis
Looking forward to getting my parts and actually getting this done I had tried to do it before and through some confusing parts and idiot installer advice i gave up, so i'm really looking forward to a new stereo
Old Dec 20, 2010 | 05:20 AM
djfrestyl's Avatar
Suspension Yoda
Ah too bad, if you were local I'd help ya out
Any questions just post em in this thread, you own it and I'm already subscribed
Old Dec 20, 2010 | 12:03 PM
02SEMax's Avatar
Thanks! I did have one question, what would you consider the best way to get the upper ac vents out? i have the shareamemory page, but i'm just kinda worried about breaking the plastic side clips
Old Dec 20, 2010 | 12:13 PM
djfrestyl's Avatar
Suspension Yoda
Hehe.
Do this. Remove the shifter trim. Remove the two screws holding the lower part of the radio/AC bracket. Then lift the lower part of the bracket to you slowly. Do it carefully. The top part of the bracket will lift, and create an opening for you to get your fingers under the lower part of the AC vents.
Old Dec 21, 2010 | 03:31 PM
02SEMax's Avatar
Hehe.
I tried this and the shareamemory ways and i just can't get those freakin side clips to come undone, is there any specific way to deal with those? It's a freakin PITA
Old Dec 21, 2010 | 07:33 PM
djfrestyl's Avatar
Suspension Yoda
uhh...no side clips. the center vents are held on with big metal clips on the bottom.
Old Dec 21, 2010 | 08:33 PM
Froggmann's Avatar
Yes it is but it gets easier the more you do it.
For me it's easier to get a small flathead screwdriver behind the bottom part of the vents and spring the clips from there. (essentially doing the same thing as lifting from the bottom of the stereo) Then put your screwdriver behind the top part of the vent straight back.
If you are still having trouble with this tomorrow. I'll put up some photos or a video of how to get the vent off since I'm changing my headunit again.
Old Dec 21, 2010 | 11:28 PM
02SEMax's Avatar
this pic showed the side ones
i seem to get the bottom ones undone b/c i can make the vents pop up, but they won't come out
I would really appreciate it, i'm just having no luck getting the vents out
Old Dec 21, 2010 | 11:35 PM
02SEMax's Avatar
Also what would you all consider the best grounding points to connect the wires to? I've heard about the ground loop if i'm not careful so i wondered where most people mounted them
Old Dec 22, 2010 | 05:16 AM
djfrestyl's Avatar
Suspension Yoda
For a HU? The TCM is held in by two 10mm bolts behind the radio, towards the base of the cavity. Just use one of those - I've never had an issue there.
Old Dec 22, 2010 | 08:22 AM
Froggmann's Avatar
That's what I used. I'll take a couple of photos tonight so you can see.
Old Dec 22, 2010 | 09:52 AM
02SEMax's Avatar
Thanks for all the help guys, you have no idea how much I appreciate it... i do have a noob question though... what's the TCM?
Old Dec 22, 2010 | 09:59 AM
djfrestyl's Avatar
Suspension Yoda
Transmission Control Module. it's the computer module looking thing at the base of the radio opening.
Old Dec 22, 2010 | 10:36 AM
02SEMax's Avatar
Oh ok, i'm still learning this stuff lol
Old Dec 22, 2010 | 10:48 AM
phatboislim's Avatar
o0o0o0o good question...its slightly audio related as in i didnt have this problem until i installed my deck..anyone have any issues with the climate control light randomly going out when you hit a button, but itll come back on by itself or if you hit on the side of it?
Old Dec 22, 2010 | 11:24 AM
djfrestyl's Avatar
Suspension Yoda
Yea, it's pretty common. Usually a loose connection - but people have had luck with replacing the inner bulbs on the unit.
Old Dec 22, 2010 | 11:26 AM
ok cool just wanted to make sure before i go all the way back in there with a failed fix
Old Dec 22, 2010 | 02:28 PM
02SEMax's Avatar
Oh another quick question, connect the dimmer wire or not connect the dimmer wire? i thought i read somewhere not to, but both the radio and the metra adapter have it so i wanted to double check
Old Dec 22, 2010 | 02:34 PM
djfrestyl's Avatar
Suspension Yoda
Your personal preference. I hardly connect it.
Old Dec 22, 2010 | 02:47 PM
02SEMax's Avatar
Ok, i'll probably go ahead and connect it since it's there
Oh and back on the whole a/c vent thing, this is the point i get to... i circled the gap, but i can't get it out past that point...
any suggestions?
EDIT: Uhhh crap, gotta tweak this real quick
EDIT AGAIN: That should be better lol
Old Dec 22, 2010 | 06:23 PM
Froggmann's Avatar
Here ya go
Wow that's dark. Let me know if I need to re-record.
Old Dec 22, 2010 | 06:36 PM
02SEMax's Avatar
Thanks! I was able to get it with that!
Now to get all the **** wired up lol
Old Dec 22, 2010 | 07:10 PM
02SEMax's Avatar
ok, so i've got the whole thing installed, radio works, etc etc... but now i'm having the same problem as froggmann... i've tried grounding the brown wire multiple places, and have had no luck getting the trip button to work... is there some trick?
Old Dec 22, 2010 | 08:31 PM
02SEMax's Avatar
Scratch this... i found that i had grounded the wrong wire... i had grounded the brown wire from the back speaker clip rather than the computer clip...
But i now have a fully functioning stereo and trip meter...
Thanks All Who Contributed!
Old Dec 23, 2010 | 05:27 AM
djfrestyl's Avatar
Suspension Yoda
Congrats
Old Dec 23, 2010 | 08:23 AM
Froggmann's Avatar
Good to hear.
Old Jan 17, 2011 | 07:22 PM
Lani's Avatar
wonderful HU Deff buy
doctorpullit
Mar 29, 2016 11:08 AM
bigfrank
Oct 1, 2015 12:51 PM
09maxshawn11
Sep 30, 2015 10:28 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
