dont knwo what sub to buy
Old Dec 19, 2001 | 07:32 PM
hockeyghst's Avatar
i am looking at 2 diff subs and i have a few questions
solo beric 12inch 2 ohm or 4 ohm
rockford fosgate power HX2 12inch 2 ohm or 4 ohm
both subs r 2000max watts and 1000rms
what is the diff between 2 ohm and 4 ohm?? thats about all i have to ask right now.....
i will also be running an off brand amp which is a Logic 1400 watt amp 1400 x 1 or 700 x 2
thanx guys
Old Dec 20, 2001 | 07:40 PM
mlsmith2
Re: dont knwo what sub to buy
Rockford makes pretty good subs, although I wouldn't buy the co-axial speaks from them, and solo beric is also good.
The difference between the 2 ohm and 4 ohm speakers is the amount of power that is needed to go. A 2 ohm speaker has 2x less resistence in the wiring so it takes less power to make sound the same loudness as a 4 ohm speaker.
Old Dec 20, 2001 | 08:40 PM
khrfadz's Avatar
thanx guys
get the kicker. i have them and love them. many peo
Old Dec 20, 2001 | 09:40 PM
MaxedOut2g's Avatar
SOLO BARIC...thats all i have to say
atw
Old Dec 20, 2001 | 11:24 PM
hockeyghst's Avatar
Re: Re: dont knwo what sub to buy
so 2 ohm is better then........
Old Dec 21, 2001 | 11:37 AM
ObsidianIce69's Avatar
Re: Re: Re: dont know what sub to buy
depends on how many subs you are going to run....the minimum ohms that your amp is stable at...
Old Dec 21, 2001 | 11:46 PM
hockeyghst's Avatar
Re: Re: Re: Re: dont know what sub to buy
i am planning on hooking up 1 12inch solo beric
my amp is max power 2ohm 700w X 2
RMS power 4ohm 350w X 2 but i plan on bridging the sub....
what is the best setup for the 1 12inch solo beric with the amp i have and what ohms should i go with???? thanx guys!
Old Dec 22, 2001 | 06:58 AM
jmax
Re: Re: Re: Re: Re: dont know what sub to buy
If your max stereo power is at 2 ohms, and max bridged power is at 4 ohms then you want a single 4 ohm sub, or a pair of 2 or 8 ohm subs.
Old Dec 22, 2001 | 08:06 AM
hockeyghst's Avatar
Re: Re: Re: Re: Re: Re: dont know what sub to buy
so i should go with the 4ohm sub and not bridge it??
Old Dec 22, 2001 | 08:41 PM
puremax's Avatar
So, basically 4ohm L7's need more power then the 2ohm ones?
Old Dec 22, 2001 | 08:53 PM
jmax
No. The same power into a different impedance. Another thing to remember is that every time you halve the impedance you halve the control the amp has over the sub. The ability of the amp to properly control the sub greatly affects the perceived volume.
Old Dec 22, 2001 | 09:13 PM
hockeyghst's Avatar
im lost man....not an expert here......
Old Dec 22, 2001 | 09:31 PM
jmax
I would get two 2 ohm subs, wire them in series and bridge the amp. 700 watts a piece is plenty of power. If if the amp is way over-rated, 350 watts should be plenty to rock those subs. Don't worry about my last post about the amps damping factor. Most people never notice this affect anyway.
Old Dec 23, 2001 | 03:26 AM
puremax's Avatar
JMAX, How long have you been into car audio?
Old Dec 23, 2001 | 04:25 AM
jim90gxe's Avatar
350w RMS per L7 IMHO is a waste of money/sub. I would go with a cheaper sub to go with that amp.
If you're going to upgrade that amp I would get L7's though.
Old Dec 23, 2001 | 06:50 AM
jmax
Ten to twelve years. Jim obviusly missed that 350 watts RMS would be the output if the amp is way over rated. The difference between 350 watts and 700 watts is only 3dB, same as the difference between 700 and 1400 watts.
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
