Installing component speakers?
Old Jan 10, 2011 | 02:14 PM
Gamble's Avatar
I've installed these in some of my cars, however none of my cars had separate tweeters. So do I just not use the wires that go to the existing tweeters and hook them up normally?
Where is the factory crossover? I assume in the headunit..
Anyone got a good place to mount the crossovers?
Old Jan 10, 2011 | 02:23 PM
NAS's Avatar
NAS
Its quite simple, there is no factory xover like an aftermarket unit. If you using the head unit to power them its simple hook up and you mount the new xover inside the door panel there is a little room in there but you will have to try different positions to see which works best for the size of xover you have.
Old Jan 10, 2011 | 02:27 PM
AscendantMax's Avatar
Mount the crossovers anywhere you can, and I would personally run seperate lines to the tweeters. The stock wires are pretty small. I have my crossovers mounted under my front seats.
I would also suggest getting a dedicated amp to power those components. The power from a head unit will not do them justice.
Old Jan 10, 2011 | 02:42 PM
Gamble's Avatar
I would, but I don't really need an interior amp. Had one in the last car and it wasn't worth it.
Old Jan 10, 2011 | 03:25 PM
IMO you'll be better off with some coaxials then. components typically perform at their best when powered by a dedicated amp. The 20 some-odd rms from the HU won't be enough.
Why was your last amp not worth it? Just curious.
Old Jan 10, 2011 | 05:20 PM
Gamble's Avatar
In my eclipse I had a alpine 7995 headunit without an internal amp. Alpine type r 6x9s for the rear, type r 6.5" components in the front, 10" alpine type r sub and 2 amps, alpine f240 and alpine m350.
I spent a good buck on this system and it was honestly good but not great. Not what I expected.
I took out the sub (I'm still doing a fiberglass enclosure, but it's too cold outside to finish) and got a newer alpine headunit and lost the internal amp and it sounds damn near identical. I didn't see the point for spending the money on all the wires, and amp and it sounding damn near the same.
I'm not looking for any fancy components for this car, simply some alpine type s will work great for what I need.
I also read that the type s walked all over the type r's a few years back. Maybe it was when I got all my stuff. In my camry I had a pioneer headunit and 6.5" type r coaxials all around and it sounded baller! However it could be speaker placement too because in my 97 eclipse the front speakers were soooo low and the rears faced you, they rears would always overpower the fronts. So who knows exactly.
Also I'm on a tight budget.
Old Jan 12, 2011 | 11:33 PM
arteom's Avatar
So where does the wire for the tweeters split? I have a 02 maxima, have already installed tweeters and woofer, cd player just installed (alpine), alpine in dash amp on the way. Crossover not yet installed. Ideally I was hoping there was a particular wire that went to tweeters on the harness, which I could splice into... I am unsure at this point, can anyone clarify Where the factory wiring for the tweeters can be spliced into? I am planning on using factory wiring, the speakers are going to be getting 45watts rms.
Any help is appreciated.
Old Jan 13, 2011 | 07:08 AM
meganaxx's Avatar
Well the type R's would be getting only most likely 50 rms each from the headunit which is still not enough for those beasts....trust me those things bang pretty loud even without a sub if you tune them right...with an amp of course...
Old Jan 13, 2011 | 07:55 AM
Gamble's Avatar
Components first, then I can always add an amp later.
Old Jan 14, 2011 | 08:48 AM
arteom's Avatar
no one knows where the tweeter/woofer wire split is located?
Old Jan 14, 2011 | 08:58 AM
Joeker82's Avatar
I would just run new leads. They are in the a pillars? Right?
Old Jan 14, 2011 | 09:00 AM
Gamble's Avatar
4th gen they are on the doors.
Old Jan 14, 2011 | 10:27 AM
Joeker82's Avatar
Here, this might help!
http://www.nicoclub.com/archives/4th...ing-codes.html
Old Jan 14, 2011 | 11:19 AM
Joeker82's Avatar
Oh yeah. The crossover is passive. Its on the back of the tweeter. Not very high tech...so the lead to your tweeter is full until it hits the tweeter
Old Jan 14, 2011 | 01:23 PM
arteom's Avatar
Well mines a 2002, the tweeters are in the pillars, it would be much easier if they were in the doors. It appears in the diagram that there is a split somewhere, does anyone know the physical location of the split in wiring?
Old Jan 14, 2011 | 01:42 PM
Joeker82's Avatar
Mine is a 01. Just run new wire. Its alot easier.
Old Feb 23, 2011 | 02:25 PM
elijahthaone's Avatar
This is where I place my x-over I just used a few house hold tools and cut out the inside of the foam and fitted for the x-over worked great
9aj9
Apr 5, 2020 12:11 AM
popdedop
Sep 11, 2015 11:17 AM
Violator
Sep 9, 2015 10:14 AM
carid
Sep 9, 2015 05:06 AM
videomano
Sep 8, 2015 03:28 PM
