DEI 530T problem
Old Apr 2, 2011 | 07:27 PM
kel456's Avatar
DEI 530T problem
where do you connect the orange wire (small wire) from the 2nd harness (530T) to if wanting 4 windows down? thanks.
Old Apr 2, 2011 | 07:47 PM
beegeezy's Avatar
Orange - ground when armed output (at the alarm) I think. I don't remember the wiring diagram.
Wait...that's for windows up. IDK, whatever the negative channel you want to use on your alarm.
Old Apr 3, 2011 | 03:11 PM
kel456's Avatar
when i get a chance i will go back to look at all the wiring and reset the alarm. 2 out of 4 windows rolling down are working and not at anytime for some reason using the remote. one-touch function sometimes work and vent function sometimes come on. only have tested at the master switch. all windows are working fine at the switch. the wires are not connected are the orange and the gray from the 530T. very strange behavior.
Old Apr 5, 2011 | 05:00 PM
kel456's Avatar
all wirings are correct. everything is working except for the 2 sets of wires that connect to the up function that i have connected to the down function. need info on how-to make it work. thanks in advance.
Old Apr 5, 2011 | 06:27 PM
partyd's Avatar
orange wire will move 2 windows in one direction UP the red and white will open both windows
also you have to cut the motor wires heavy gauge wires to the motors and litle gauge wire to the cables comming from the switch
if your motors are old and tired you will need to modifie the 530t there are some resistors you need to change so it don't stop half way
http://www.directeddealers.com/manua...N530T_1-00.pdf
Old Apr 5, 2011 | 06:57 PM
kel456's Avatar
i have used the correct wires and have flip the resistors to the highest. is there a mod to have all 4 windows roll down?
Old Apr 5, 2011 | 07:05 PM
partyd's Avatar
The 530T window system controls the operation of two motors only in both the up and down directions
for 4 windows you need 2 530t
or you can use 2 529t but they move the motor in one direction only
Old Apr 5, 2011 | 07:08 PM
partyd's Avatar
look at the wiring and make sure it is ok , if the windows sometimes stop or don't close all the way you can modified the 530t brain, but this is not going to solve any wirign problem
and be very carefull when doing this
http://www.p71interceptor.com/window...tip1900ocr.pdf
Old Apr 5, 2011 | 07:23 PM
beegeezy's Avatar
+1
Yeah, I missed that. If you want to control all four windows (up and down) you need two 530t modules.
Old Apr 5, 2011 | 08:18 PM
kel456's Avatar
damn, it's disappointing. i read several posts that 530T has the option of controlling 4 motors in one direction or controlling 2 motors up & down. if i had the correct info i would get 2 529T instead.
partyd, appreciate the PDF.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
