Subs in 5th gen
Old Dec 24, 2001 | 11:39 AM
Punch84's Avatar
Subs in 5th gen
I have a 2K max without the Bose and am considering adding 2 10's. My question is would it be a good idea to cut a hole where the Bose sub would have been and buy the Bose "grate" and put it over it? This, I think, would air to move between to trunk and cabin making it sound cleaner and possibly eliminating folding the back seat? Has anyone done this or think it is a good idea? Thanks, Dave.
Old Dec 24, 2001 | 11:42 AM
maximadave's Avatar
detailerdaveb@gmail.com
Re: Subs in 5th gen
Dont do it that way. Build a fiberglass enclosure on the left rear corner of your trunk if you want to save space and only have 1 sub. Or you can build a small downfire enclosure for 1 10 or 12" sub right behind the seat with minimal space...
Old Dec 24, 2001 | 01:27 PM
irvine78's Avatar
Re: Subs in 5th gen
air subs are bad..only good in trucks where u have very limited space.
Old Dec 24, 2001 | 04:03 PM
max'n out's Avatar
Re: Subs in 5th gen
I did. I did more to it to. But that by it self should be fine.
Old Dec 24, 2001 | 09:07 PM
rob van dam's Avatar
hummmm
i took my bose sub out and covered the hole with the bose grill.....i guess you could say it vents the bass through the hole....i never let my back seats down..its loud enough without doing that...
Old Dec 25, 2001 | 07:47 AM
DMAN11's Avatar
Re: hummmm
Hey "R"V"D",,,,hehe....I built a fiberglass box in the passenger side of the trunk over the wheel well. I have a 10" sub in it. I too was thinking of doing the same thing, cutting a "port" if you will in the back dash to allow air flow through to the cabin. How is it working for you, and if you did, where did you get the grill from to cover the hole? Did it quiet any of those little rattles that were around? Thanks,,,,D-MAN
Old Dec 25, 2001 | 10:28 AM
Punch84's Avatar
Thanks for all the comments. I am only planning on using the "Bose hole" as a "port". Does anyone know where I would be able to obtain one of those Bose "grates"?
Old Dec 25, 2001 | 11:25 AM
max'n out's Avatar
Nissan, I think it's like 15 bucks
Old Dec 25, 2001 | 06:51 PM
Re: Re: hummmm
I have an AE maxima...it came with a bose sub and the grille.....i just had the sub unhooked after i blew it out(i play my bass loud).....then i covered the hole with the grille.......i have an enitre dynamat trunk kit plus extra dynamat under the actual panel....my 2 12w3's sound great with basically no rattling!
MAXSE5SPD
Sep 17, 2022 04:00 AM
dcam0326
Sep 18, 2015 04:52 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
