Will this setup work? Help Please
Old Jun 4, 2011 | 11:14 PM
yankeefan13's Avatar
hey I'm redoing my stereo system in my car, I have a relativley new HU so I dont need that, but pretty much everything else. I was wondering will these all work together? (Got 4 of the same Kenwood speakers for the doors, 1 amp,1 sub, and 1 pair of tweeters)
Planet Audio AC1800.5
1800W MOSFET 5-Channel Power Anarchy Series Car Amplifiers
Kenwood KFC-1682ie
6-1/2" 240W 3-Way Car Speakers
Kenwood KFC-ST30
1" PI Balanced Dome Tweeters
Pioneer Premier TS-SW841D
8" 500W 4-Ohm Shallow Mount Subwoofe
Old Jun 4, 2011 | 11:37 PM
maxed_out_99's Avatar
do you plan on bridging it? if so i think you may have to turn the amp down quite a bit so you dont blow dem subs
Old Jun 5, 2011 | 08:17 AM
Well im just buying the speakers and stuff and having someone else install them, but I dont plan on bridging them
Old Jun 5, 2011 | 08:47 AM
AscendantMax's Avatar
you don't need the extra set of tweeters...your coaxials already have them built-in. as for the amp, it might not work with your subwoofers if you have them wired down to 2 ohm (your amp might not be stable). you won't blow them though.
Old Jun 5, 2011 | 02:26 PM
okay thanks, but what amp would I need then? And I thought i would need another set of tweeters because I have some already in the A-pillar trim stock.
Old Jun 6, 2011 | 05:35 AM
nismos14's Avatar
§è~® f®ÈÄk
No you don't need them, it's up to you, ideally a set of components up front is the correct way to go. Following the logic you're using, the front doors have midbass speakers, then you have the tweeters, so a comp set is a direct replacement, not a coaxial and a separate tweeter.
Old Jun 6, 2011 | 08:51 PM
Oh alright, so should I just leave the stock tweeters alone then?
Old Jun 7, 2011 | 04:24 AM
nismos14's Avatar
§è~® f®ÈÄk
Yes, just disconnect them.
Old Jun 7, 2011 | 07:57 AM
ah alright thanks
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
