indiglo gagues problem
Old Mar 6, 2012 | 02:53 PM
trapp_king's Avatar
I just installed indiglo gauges on my 01 se and they look great only one problem when i put the cluster back in all of my needles are way off. I guess i shouldnt have taken them off but there was no other way to get the gauges in there. Also having some trouble finding a power and ground source for the gauges. Has anyone else done the indiglo gauges on a 5th gen because i couldnt find any how to's on here.
Old Mar 6, 2012 | 02:55 PM
You're gonna have to figure out how to recalibrate the needles. You couldn't just slip the gauges on? I remember I was able to in my 4th gen.
For power and ground, I tapped into the dimmer switch.
Old Mar 6, 2012 | 03:07 PM
trapp_king's Avatar
yeah i was gunna tap into dimmer switch but i have 3 wires and i cant figure out what they are i have red/yellow (which i think is illumination to radio) red/white and black
anyone have info on how i can recalibrate my needles?
Old Mar 6, 2012 | 03:12 PM
Mine had three wires as well but were different colors. Grab a test light and figure out which one gets power when the lights are turned on. Black is probably ground so it's either the red/yellow or red/white. Simple enough.
Sorry, I can't help you with the needle calibration.
Old Mar 8, 2012 | 05:07 AM
trapp_king's Avatar
can anyone help with needle calibration?
Old Mar 12, 2012 | 07:06 PM
trapp_king's Avatar
ok ok so heres what i learned. To calibrate needles i drove next to my friend who was going 60 on cruise control and matched my cruise to his then placed the needle and for RPM's i guessed the idle speed around 1100 rpms as for the gas i filled up my tank and threw the needle on full and temp i ran my car for a while and threw the needle a litttle less than half way...as for the indiglo gauges power source i was able to borrow a friends test light and poke it into each wire...turns out the red/white wire was the one i needed so i bought one of these connectors specially made for splicing a wire into another wire hooked it up then used the test light to find a ground and bingo the lights are sick check em out
Old Mar 12, 2012 | 07:23 PM
Amerikaner83's Avatar
Idle speed when warm is 650 rpm thereabout
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
