No subs need help
Old Aug 3, 2012 | 05:40 PM
tallguesse07's Avatar
No subs need help
Ok so i read the threads ppl put up before me have a 99 maxima i spliced the rca wires in to my rear speaker wires and im still not getting anything from my sub im back tracking to see if i did anything wrong but so far its good but i still have no sound out my eclipse sub
Old Aug 5, 2012 | 09:25 PM
cmd26's Avatar
Dont you need an amp to power a sub?
Old Aug 6, 2012 | 12:46 AM
yeah have the amp and the subs hooked up but not getting any sound im getting the signal off the rear speakers
Old Aug 6, 2012 | 08:35 PM
installer's Avatar
did you use a hi lo converter
Old Aug 6, 2012 | 09:59 PM
2brosgixxer's Avatar
You need one of these http://www.sonicelectronix.com/item_...Boss-B65N.html if you are not plugging your RCA's into the head unit. Then you can splice those wires into the existing speaker wires, then plug the RCA's in. You cant just cut the RCA cables and splice them into the existing speaker wire.
Old Aug 7, 2012 | 08:03 AM
CRiME's Avatar
oem ftw!
That depends on if he has a bose system or not. If he does have bose, he can splice his RCA's into his rear speaker harnesses, as long as he taps the signal before it passes through the amps. Many people have done it this way, I did it on my brother's 5th gen, also did it as a temporary thing when I had my 4th gen. worked out fine.
OP: need a little more info. Is your amp at least turning on??
Old Aug 7, 2012 | 10:49 AM
yeah the amp turns on and its a bose kinda y i didnt get the hi low converter but i still get no sound from my subs
Old Aug 7, 2012 | 01:19 PM
CRiME's Avatar
oem ftw!
Ok, have you tried the amp in another car to make sure it's good, or do you have another amp you can try in your car?
Apart from that, the only other thing I can suggest is to check and re-check your wiring. Are you splicing the RCA's into the harness, before they reach the bose amps? Make sure that you have the (+) and (-) correct on your RCA's. maybe try switching them just to eliminate that. You probably have these diagrams already but just posting them in case:
Good luck man
Old Aug 8, 2012 | 03:40 PM
Good luck man
ill recheck again just to make sure but the amp i got was off of my friends car so i know it works i think it might be the wiring
Old Aug 8, 2012 | 05:11 PM
CRiME's Avatar
oem ftw!
Alright, post back if you find anything...
Redfox
Sep 28, 2015 10:41 AM
Taino14
Sep 24, 2015 02:51 PM
ballerchris510
Sep 23, 2015 08:46 PM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
