Pics of Custom trunk installs
Old Jan 11, 2002 | 03:29 PM
puremax's Avatar
I need some ideas for my new install. Can you guys post some pics of your custom installs. Thanks.
Old Jan 11, 2002 | 06:19 PM
max'n out's Avatar
Do a search theres a hundred of the same question with this same title. It will be easy to find.
Old Jan 11, 2002 | 11:00 PM
Brandon90gxe's Avatar
just wait about a day..
Old Jan 12, 2002 | 07:02 AM
Maxstilln's Avatar
Re: Pics of Custom trunk installs
Check the post futher down on the board, all kinds of pictures of custom trunk installs but try to do something orginal, be different.
https://maxima.org/forums/upper-midwest/86997-suspension-work-chicago.html
Old Jan 12, 2002 | 08:46 AM
Shugarhi's Avatar
Old Jan 13, 2002 | 12:41 AM
Ahh after 2 days, my custom trunk setup is DONE.. i really enjoyed it, my friend Dan and I started from scratch and this is what we got. Im really impressed and thrilled because i must say it came out perfect.We even installed a fan to cool and red LED's around to make it glow. It might not be the biggest setup, but im happy with what i got. Heres the pics..no the plexy isnt cracked.. the pic just came out that way..
Click here to see pics of the whole install
what you guys think?
Old Jan 13, 2002 | 05:34 AM
Botos's Avatar
More pics at http://www.botos.com/matthew/maxima/
Old Jan 13, 2002 | 06:45 AM
jmax
Brandon,
My experience with amps, MTX included, is that that amp will shut down in 45 minutes or less on a hot day(most likely 10-20 minutes tops). I would get rid of or at least perforate the plexi. Or maybe cut some slits in it to allow it to vent.
Old Jan 13, 2002 | 10:02 AM
Maxstilln's Avatar
Looks good, I agree with jamx, vent the plex or put a fan in there. MTX amps can run very hot and it might shut down on you You can get a fan from Radio Shack for $15 and then just tap the remote turn on to a relay to turn on the fan when you turn on the system automaticaly. It will be worth your time in the long run
Old Jan 13, 2002 | 09:24 PM
DMAN11's Avatar
Nice Job Brandon....
Hey Brandon,
Nice job bud, I just have one comment, and one question. First off, the only thing I may have tried to do was maybe pull off that Q grill, and see if you coule throw a layer of the same carpet over that box too, then throw the grill back on. That way you have a perfect match of carpet all the way across. That's just me dude, it looks really cool. My question is this,,,,how do you have that plexi on,,,screws, glue, silicone??? can't see anything in the pics...Thanks...DMAN
Old Jan 14, 2002 | 03:46 AM
2kBlackMax's Avatar
Custom trunk
How did u secure the panel to the trunk?
Old Jan 15, 2002 | 02:30 PM
Chitwista's Avatar
Check out my Webpage listed under my name.. I have pictures of my install there.. LET ME KNOW WHAT YOU THINK
Old Jan 15, 2002 | 05:39 PM
95emeraldgxe's Avatar
i like the "flush" look - but i hate the fact that i lose trunk space....grrr
Old Jan 15, 2002 | 07:57 PM
Y2KMaxGXE-R's Avatar
I want something like Brandon's install on my ride..very clean looking install, nice job. Except maybe that I'd have 2 subs there instead of a one. Brandon, how do you like your spare access? What is the total weight of that staff? How do you take precise measurments of your trunk?
Old Jan 16, 2002 | 09:58 PM
oops.. forgot about this thread..
guys guys.. cmon, at least click the link! i did put a fan in there! i built it in to the top of the box that holds the amp so thers plenty of venilation. i even wrote it right in the thread!! We even installed a fan to cool and red LED's around to make it glow. hehe all guud, so anyways, the plexy is actually held in by itself, the surround for it is cut perfectly so that the carpet around it holds it in place.
At first i was thinking about carpeting over the sub box too, but there wasnt really a good way to do it, and if i cut out a hole just for the silver part int he wood the sub would be behind the wood and it wouldnt look flush.
Oh spare access is not bad, i didnt cut the wood underneath but i can still pull it up to access the tire no problem. Theres actually plenty of room left in the trunk. The wieght is not bad at all, maybe like 15 pounds of wood thats it. I secured it with an l bracket to the rear deck, and im goin to put an L bracket to the floor carpet too, but it really doesnt move around at all. even with my driving.
IM pretty happy with my one 12". A lot of people cant believe im only runing 1 12 with the amount of bass i get.
Anyways, im happy to answer any other questoins, if you wanan see how everythign was wired and all click that link!
Old Jan 17, 2002 | 06:31 AM
jmax
"We even installed a fan to cool and red LED's around to make it glow." - Brandon
Yeah, I read that but couldn't see any space around the edges of the amp. Is the back side of the amp exposed, for ventilation? And where does the fan vent? It doesn't help to circulate 150 degree air.
Old Jan 17, 2002 | 12:12 PM
The fan blows up toward the rear deck, and theres about an inch gap between the rear deck and the wood wall, so the air escapes through there, you can feel it when you put you fingers in the gap..
Old Jan 17, 2002 | 08:19 PM
jmax
Cool. And, oh yeah, cool!
Matt93SE
May 24, 2019 02:58 PM
Roman777NYC
Nov 7, 2015 10:13 PM
95Maxi
35
Sep 2, 2015 10:37 AM
Team STILLEN
Aug 10, 2015 04:29 PM
