Upgrading stereo system to 7inch dvd player...help ?
Old May 7, 2013 | 05:35 PM
Dondon321's Avatar
I have the double din bose unit already,
looks like this https://imageshack.us/a/img203/7271/opt20130507192640632.jpg
and want to upgrade to this http://www.amazon.com/gp/aw/d/B004AUFJ48
Will I need any extra things to make it work? Or just plug and play? I have little knowledge about car audio but I learn fast. And also my rear bose speakers blew out, if I replace thos with pioneer speakers will they work with the two front bose? Or will I have to buy two more new speakers in the front ?
Thanks ! Btw heres a picture of my car
https://imageshack.us/a/img405/3601/opt20130430182639783.jpg
Old May 7, 2013 | 07:09 PM
bprice92's Avatar
Previous threads, found by searching:
Din threads:
http://forums.maxima.org/audio-elect...s-4th-gen.html
http://forums.maxima.org/audio-elect...y-96-bose.html
Replacing bose:
http://forums.maxima.org/audio-elect...nt-thread.html
http://forums.maxima.org/audio-elect...ggestions.html
http://forums.maxima.org/audio-elect...96-maxima.html
Conclusion - need adapter for clean look, need wire harnesses from din to stock harness.
Id would replace all 4 and have them be powered off the headunit. dunno what else you need to bypass stock amp, if there is one, I would try searching.
Old May 7, 2013 | 09:15 PM
Dondon321's Avatar
Thank you kind sir
Old May 7, 2013 | 09:18 PM
milo2223's Avatar
Just get a nissan stereo harness fro your local auto parts store, if you get the speakers u will need to run wires all the way to the head unit, u can NOT use the stock amps or plugs to power those speakers, so get all 4 or just get 2 bose speakers and ur done, I want a 7" am running a 6.1 on my car wiyh all 4 bose speakers and stock amps and sounds great ;-) only reason I changed the bose unit was the lack of aux jack... Hope that helps and if u have any questions let me know...
Old May 7, 2013 | 09:35 PM
Dondon321's Avatar
So would it be easier if I just bout two rear bose speakers?
Old May 8, 2013 | 07:08 AM
max ride 41's Avatar
it would be easier if you made any sense at all as to what your trying to do.
Old May 10, 2013 | 08:20 PM
Dondon321's Avatar
could I replace the rear bose speakers with another set of bose without having to run new wires to the head unit ?
Old May 14, 2013 | 09:58 PM
Dondon321's Avatar
Nvm, upgraded. :+)
Dasmith
Sep 23, 2015 08:28 PM
