Whats the best kind of box for this sub???? help!
Old Jan 19, 2002 | 11:15 AM
95maxgxe's Avatar
Needs only a 0.8-1.6 cu.ft. sealed or 1.3cu.ft. ported enclosure | 120 oz. Magnet | Power Handling: 700 watts RMS | Freq Resp: 20Hz – 500Hz | Efficiency: 92.7 dB | 2.5" 4-Layer Voice Coil | Mounting Dimensions: Depth; 5 5/8" Hole; 11 1/8" Diameter; 12 3/4"
its a 12 inch audiobahn AW1200, i know it says ported/sealed, but i dont even know what that means. Help! im new at this
Old Jan 19, 2002 | 02:11 PM
jmax
It tells you in the first sentence. Ported or sealed. It depends on what type of music you listen to and how you listen to it. And how critical are your ears? If you are like the average person you are more interested in ****ing off the people across from you at intersections, go with ported.
Old Jan 19, 2002 | 02:12 PM
95maxgxe's Avatar
i mainly listen to rap.....and yeah i want people to hear it, so i should go with ported right that just means it has the hole in the box correct? i can get at least that from the name, i told u im new at this!
Old Jan 19, 2002 | 02:40 PM
jmax
Basically yes. Make sure you get the port length and diameter. And make sure you make the box as near the exact volume they advise for that tuning frequency, or it will be tuned wrong. The volume does not include bracing, driver, or port.
magiconthetire
Oct 26, 2015 09:03 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
Sep 27, 2015 08:37 AM
Stagnet04
Sep 14, 2015 11:28 PM
